[OpenLayers-Users] Problem with Trac notifications
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Oct 19 08:01:54 EDT 2008
The "Reported by" contains my OL login, from which my email is avalible.
Regards, Kenneth Skovhede, GEOGRAF A/S
Eric Lemoine skrev:
> You may also get notifications if the reporter field includes your
> email address. For this to work it may be that the
> always_notify_reporter must be set to true in the trac configuration,
> and I don't if that's the case in the OpenLayers trac configuration.
> Chris, do you know?
> And I don't know if it's possible to configure trac so that reporters
> are automatically notified without having to put their email addresses
> anywhere.
> Eric
> 2008/10/19, Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
>> Yes, but shouldn't it be the default?
>> If a user adds a ticket, there will usually be a follow up question,
>> and the user will most likely be interrested in any progress on the issue.
>> Not sure how it works, but other Trac systems do this automatically,
>> eg. MapGuide, FDO, and Google Code.
>> Eric Lemoine skrev:
>>> Yes. If you just want to receive messages of a specific ticket add
>>> your email to that ticket's CC: field. Eric
>>>> Then I will recieve all messages generated by the trac system?
>>>> It's a bit much for following a few issues, but alright.
>>>> Eric Lemoine skrev:
>>>>> Hi. Have you registered to the trac mailing list? If not go to the
>>>>> OpenLayers list registration page and register to trac at openlayers.org.
>>>>> Eric
>>>>>> I'm having some trouble with the Trac notification system.
>>>>>> I only get email notifications when I write a message on a ticket
>>>>>> myself.
>>>>>> If others respond to a ticket that I created, there is no notification.
>>>>>> I have used other Trac systems before without this problem.
>>>>>> Can I modify something to fix it, or is it meant to be that way for OL?
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
