[OpenLayers-Users] WKT 2 KML
Christopher Schmidt crschmidt at metacarta.com
Wed Oct 22 16:39:54 EDT 2008
On Wed, Oct 22, 2008 at 04:02:09PM -0400, Heidt, Christopher M. wrote:
> Ok, I have two visulation clients: One uses OpenLayers, the other uses
> the GoogleEarth Plugin API.
> The OL client is my main squeeze and i build all functionality with it
> first.
> I then later add the functionality to the GE client.
> OL has an great wkt parser that i have grown to love, but GE is kml
> only.
> Basically i need a way to convert WKT into KML.
> So the question comes down to this:
> In an effort to reduce load times,
> if all i want to be able to do is convert WKT to KML,
> what is the minimum set of files required to pull it off?
Making a build profile from
http://trac.openlayers.org/browser/sandbox/crschmidt/projection/build/reproject.cfg?rev=6000
probably gets you pretty close.
> The data will be parsed on a shape by shape basis if that helps any.
> i.e. 1 shape per WKT String
> If there are any other options out there please let me know.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
