[OpenLayers-Users] Clustering and addFeatures method
Salvaro asufsc at gmail.com
Fri Oct 24 08:38:15 EDT 2008
Hi Jacolin,
Yes, I saw it, thanks :).
The problem probably should be with the reprojection of the points, with
opacity is possible to see the points being clustered, but when zooms in the
map, they stay at the same position.
Thanks!
Jacolin Yves wrote:
> Le Friday 24 October 2008 14:07:10 Salvaro, vous avez écrit :
>> I'm using a vectorLayer over two different baselayers (WMS and Google
>> Maps
>> Layer).
>> The cluster strategy works well when I'm using the WMS, but when I change
>> the baseLayer to the GMaps layer it stops.
>> I've to do something "different" to fix it in the GMaps Layer? Or it
>> should
>> work?
>> Thanks!
> Hi Salvaro,
> It should work, as you can see here: http://softlibre.free.fr/ol/test.html
> Regards,
> Y.
> Yves Jacolin
> http://softlibre.gloobe.org
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Clustering-and-addFeatures-method-tp1341276p1371882.html
