[OpenLayers-Users] Clustering and addFeatures method
Salvaro asufsc at gmail.com
Fri Oct 24 09:11:43 EDT 2008
Now with correct reprojection (and using only GMaps Layer) it still isn't
work.
Looks like the strategy is being ignored by the GMaps Layer, the points
ignore the distance, and if I clustered they before change the layer (5
points clustered in 3 points for an example), GMaps only shows these 3
points.
When "come back" to the WMS it works, but only show the 3 points.
Thanks,
Salvaro.
Salvaro wrote:
> Hi Jacolin,
> Yes, I saw it, thanks :).
> The problem probably should be with the reprojection of the points, with
> opacity is possible to see the points being clustered, but when zooms in
> the map, they stay at the same position.
> Thanks!
> Jacolin Yves wrote:
>> Le Friday 24 October 2008 14:07:10 Salvaro, vous avez écrit :
>>> I'm using a vectorLayer over two different baselayers (WMS and Google
>>> Maps
>>> Layer).
>>> The cluster strategy works well when I'm using the WMS, but when I
>>> change
>>> the baseLayer to the GMaps layer it stops.
>>> I've to do something "different" to fix it in the GMaps Layer? Or it
>>> should
>>> work?
>>> Thanks!
>> Hi Salvaro,
>> It should work, as you can see here:
>> http://softlibre.free.fr/ol/test.html
>> Regards,
>> Y.
>> Yves Jacolin
>> http://softlibre.gloobe.org
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Clustering-and-addFeatures-method-tp1341276p1371983.html
