[OpenLayers-Users] How to add many(>400) markers to the map?
Lehtonen, Mika mika at digikartta.net
Tue Apr 14 06:01:45 EDT 2009
if you were using Geoserver and wms, dynamic symbolizer could help you.
Check the following out:
http://blog.geoserver.org/2008/12/08/dynamic-symbolizers-part-1/
- mika -
willson kirjoitti:
> Hi,
> try to search mailing list for strategies, performance. I have the same problem not solved yet. It looks I will have to render at server site.
> Michal
> Hi everyone, this is the first post on this forum. I have search the problem on the forum, but find no anwser.
> What I need to solve is:  I have more than 400 points need to show on the map, these points query my db every 10 secs, and change their color according to the return value.
> I use the openlayers.layer.marker to implement, but in ie the markers make the map so slow when zooming.
> Then I move to  openlayers.layer.vector, but it's even slower than marker.
> Any suggestion in such "Adding large and dynamically changed markers"  situation?
> hi, render in serverside(may be wms) can improve the performance much, but how to make markers dynamically change color? Any solution?
