[OpenLayers-Users] Modifiable Feature - a minimum area
Chris Jones
cijones at lycos.com
Mon Apr 20 03:41:50 EDT 2009
Thanks for your input Eric. Following your lead I've had a quick look at the trunk, and there is also a sketchstarted\modified\complete which might be what I'm looking for.
Failing that, would it be possible to either use the mouse handler or renderer to achieve the behaviour I'd like?
Hi. In trunk the vector layer has the new event type "vertexmodified",
so I was going to suggest to use that when I realized that
"vertexmodified" will not be triggered when a *virtual* vertex is
moved. Maybe someone has a better idea... If not the only thing I can
think of is proposing the addition of a "virtualvertexmodified" or
something.
Cheers,
Eric
2009/4/17, Chris Jones <cijones at lycos.com>:
> Hi,
> I have a feature drawn on a vector layer, is there a way to enforce a
> minimum\maximum size on it while it is being modified by a ModifyFeature
> control?
> I'd hoped that I'd be able to get an event to tell me everytime the feature
> had been changed (ie when it is redrawn) which I could then use to evaluate
> the new area and check it is above\below the min\max. Is there an event to
> allow this, or I am looking at it the wrong way, and there is there a
> better\alternative control\handler combination that can be used to achieve
> the correct behaviour?
> Thanks for any help.
> Chris
> (I originally posted this to the dev group, so sorry if it's your second
> time of reading).
> http://n2.nabble.com/Modifiable-Feature---a-minimum-area-tp2644720p2644720.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Envoyé avec mon mobile
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
Users mailing list
View this message in context: http://n2.nabble.com/Modifiable-Feature---a-minimum-area-tp2644720p2662235.html
