[OpenLayers-Users] Modifiable Feature - a minimum area
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Apr 21 02:57:24 EDT 2009
On Mon, Apr 20, 2009 at 9:41 AM, Chris Jones <cijones at lycos.com> wrote:
> Thanks for your input Eric. Following your lead I've had a quick look at the trunk, and there is also a sketchstarted\modified\complete which might be what I'm looking for.
> Failing that, would it be possible to either use the mouse handler or renderer to achieve the behaviour I'd like?
I just gave it a try and I was wrong: "vertexmodified" gets triggered
at some point when a *virtual* vertex is moved, so that may be the
only event type you'd have to listen to.
Regards,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
