[OpenLayers-Users] 'Fluid' map in IE
sendeman
martijnsendenspam at gmail.com
Wed Apr 22 05:00:34 EDT 2009
Hi All,
Last week I managed to set up a simple localhost map server using Openlayers
and UMN Mapserver. It all worked, across all modern browsers. It was however
a straightforward example wit a map that had a fixed width and height. In
the real page I'm making, the map needs to be in a div that is positioned as
follows:
#map {
position: absolute;
top: 90px;
left: 10px;
right:10px;
bottom: 36px;
In Firefox this works, but of course, IE can't handle both a top and a
bottom declaration on one element (nor both a left and a right declaration).
The way I normally solve this is by adding extra stylesheets for versions of
IE. I load them using conditional comments.
The IE7 stylesheet would look like this:
#map {
height: expression(document.documentBody.clientHeight - 126 +"px");
width: expression(document.documentBody.clientwidth - 20 +"px");
The IE6 stylesheet would look like this:
#map {
height: expression(document.documentElement.clientHeight - 126 +"px");
width: expression(document.documentElement.clientWidth - 20 +"px");
All that works in IE, as long as I don't try to add an Openlayers map to the
div. I guess the problem is that IE handles the CSS after it handles the
Openlayers javascript and therefore Openlayers thinks the height and width
of the #map div are undefined (or zero?). It therefore renders the
#map_OpenLayers_ViewPort div with a zero height.
I tried solving this by setting the height and width of the #map div through
javascript (not a really elegant solution, I'd rather do it through css and
without too much additional markup in the html), but didn't get it to work.
I read the http://n2.nabble.com/Map-size-without-javascript-td2661939.html
thread by Ian Gibson , but the solution he found doesn't seem to work for
me.
Does anyone here have a possible solution to this issue? If not possible by
CSS then Javascript will have to do. Many thanks in advance for any help.
Best regards,
Martijn Senden.
View this message in context: http://n2.nabble.com/%27Fluid%27-map-in-IE-tp2674997p2674997.html
