[OpenLayers-Users] 'Fluid' map in IE
sendeman martijnsendenspam at gmail.com
Wed Apr 22 17:31:31 EDT 2009
Hi All,
Has anyone read message today? I see it's only been viewed once. Does anyone
have any ideas on how I could approach the described problem?
Again, may thanks in advance.
Best regards,
Martijn Senden.
sendeman wrote:
> Hi All,
> Last week I managed to set up a simple localhost map server using
> Openlayers and UMN Mapserver. It all worked, across all modern browsers.
> It was however a straightforward example wit a map that had a fixed width
> and height. In the real page I'm making, the map needs to be in a div that
> is positioned as follows:
> #map {
>    position: absolute;
>    top: 90px;
>    left: 10px;
>    right:10px;
>    bottom: 36px;
> In Firefox this works, but of course, IE can't handle both a top and a
> bottom declaration on one element (nor both a left and a right
> declaration). The way I normally solve this is by adding extra stylesheets
> for versions of IE. I load them using conditional comments.
> The IE7 stylesheet would look like this:
> #map {
>    height: expression(document.documentBody.clientHeight - 126 +"px");
>    width: expression(document.documentBody.clientwidth - 20 +"px");
> The IE6 stylesheet would look like this:
> #map {
>    height: expression(document.documentElement.clientHeight - 126 +"px");
>    width: expression(document.documentElement.clientWidth - 20 +"px");
> All that works in IE, as long as I don't try to add an Openlayers map to
> the div. I guess the problem is that IE handles the CSS after it handles
> the Openlayers javascript and therefore Openlayers thinks the height and
> width of the #map div are undefined (or zero?). It therefore renders the
> #map_OpenLayers_ViewPort div with a zero height.
> I tried solving this by setting the height and width of the #map div
> through javascript (not a really elegant solution, I'd rather do it
> through css and without too much additional markup in the html), but
> didn't get it to work.
> I read the
> http://n2.nabble.com/Map-size-without-javascript-td2661939.html thread by
> Ian Gibson , but the solution he found doesn't seem to work for me.
> Does anyone here have a possible solution to this issue? If not possible
> by CSS then Javascript will have to do. Many thanks in advance for any
> help.
> Best regards,
> Martijn Senden.
View this message in context: http://n2.nabble.com/%27Fluid%27-map-in-IE-tp2674997p2679395.html
