[OpenLayers-Users] WMC and multi-url in OpenLayers 2.7
Andreas Hocevar ahocevar at opengeo.org
Thu Apr 23 08:54:53 EDT 2009
Kralidis,Tom [Ontario] wrote:
> Correct, WMC 1.1.0 allows one Server element with one OnlineResource element.
> I'm not sure whether OL supports OWS Context, but there you can define multiple Servers, and / or multiple OnlineResource URLs within a Server element, to handle something like this.
Currently OpenLayers does not support OWS context, because we are
uncertain if its state. Tom, can you maybe enlighten us: Will OWS
context become an OGC standard soon? Where can we find the current spec?
Is the spec already stable?
Thanks a lot!
Andreas.
> ..Tom
>> -----Original Message-----
>> From: users-bounces at openlayers.org
>> [mailto:users-bounces at openlayers.org] On Behalf Of Jacolin Yves
>> Sent: Thursday, 23 April 2009 05:33
>> To: Users at openlayers.org
>> Subject: Re: [OpenLayers-Users] WMC and multi-url in OpenLayers 2.7
>> Hi Andreas,
>> Thanks for your reply. Indeed it sounds normal among the WMC spec.
>> Here is the tickets : http://trac.openlayers.org/ticket/2059
>> I am not sure if I am able to provide a patch as I am not a
>> javascript developer.
>> Regards,
>> Y.
>> Le Thursday 23 April 2009 11:11:40 Andreas Hocevar, vous avez écrit :
>>> Hi Yves,
>>> the problem is that there is no concept of multiple server
>> urls in WMC.
>>> If you look at the schema for WMC 1.1, you will see that the
>>> ServerType in the Layer has exactly one occurrence, and the
>>> OnlineResource inside the ServerType also has exactly one
>> occurrence.
>>> So the issue in Format.WMC.v1 is that the content of
>> layer.url will be
>>> written to the OnlineResource's xlink attribute, which will
>> produce an
>>> invalid value (comma-separated list of urls) if the layer's
>> url is an
>>> array. The question is whether we just want to write the
>> first url, or
>>> an additional vendor extension value that stores all other urls.
>>> Anyway, this deserves a ticket. Yves, if you are interested
>> in getting
>>> this fixed, we would appreciate if you could create this ticket and
>>> maybe even provide a patch.
>>> Regards,
>>> Andreas.
>>> Jacolin Yves wrote:
>>>> Hello,
>>>> I am using WMC OGC service to allow users to print my map with
>>>> another design. Using multi-URL in OL give something like this in
>>>> the WMC
>>>> context: <Layer queryable="0" hidden="1">
>>>>   <Server service="OGC:WMS" version="1.1.1">
>>>>     <OnlineResource xlink:type="simple"
>>>> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="
>>>> http://www.lpdipro.dev.local/tilecache/tilecache.py,
>>>> http://www1.lpdipro.dev.local/tilecache/tilecache.py,
>>>> http://www2.lpdipro.dev.local/tilecache/tilecache.py,
>>>> http://www3.lpdipro.dev.local/tilecache/tilecache.py"/>
>>>>   </Server>
>>>>   <Name>ratp_ligne_metro</Name>
>>>>   <Title>ratp_ligne_metro</Title>
>>>> I added space between each url to improve readability.
>>>> In OL code, after applying the context, the url of tile are:
>>>> http://www3.lpdipro.dev.local/tilecache/tilecache.py?
>>>> VERSION=1.1.1&FORMAT=image%2Fjpeg&
>>>> LAYERS=cadastre&SERVICE=WMS&REQUEST=GetMap&
>>>> STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&
>>> SRS=EPSG%3A900913&BBOX=89321.71190000002,6171789.4407,245864.74580000
>>>> 003,
>>>> 6328332.4746& WIDTH=256&HEIGHT=256
>>>> Again return line and space added for readability.
>>>> Is it something known and how to correct this? Do I need
>> to create a
>>>> bug report, example?
>>>> Thanks,
>>>> Y.
>>>> PS : I am going to test the new OL 2.8RC1 release.
>> Yves Jacolin
>> Ne demandez pas si vous pouvez contribuer, contribuer ! :)
>> http://softlibre.gloobe.org
>> Users mailing list
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
