[OpenLayers-Users] WMC and multi-url in OpenLayers 2.7
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Thu Apr 23 08:03:02 EDT 2009
Correct, WMC 1.1.0 allows one Server element with one OnlineResource element.
I'm not sure whether OL supports OWS Context, but there you can define multiple Servers, and / or multiple OnlineResource URLs within a Server element, to handle something like this.
..Tom
> -----Original Message-----
> From: users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org] On Behalf Of Jacolin Yves
> Sent: Thursday, 23 April 2009 05:33
> To: Users at openlayers.org
> Subject: Re: [OpenLayers-Users] WMC and multi-url in OpenLayers 2.7
> Hi Andreas,
> Thanks for your reply. Indeed it sounds normal among the WMC spec.
> Here is the tickets : http://trac.openlayers.org/ticket/2059
> I am not sure if I am able to provide a patch as I am not a
> javascript developer.
> Regards,
> Y.
> Le Thursday 23 April 2009 11:11:40 Andreas Hocevar, vous avez écrit :
> > Hi Yves,
> > the problem is that there is no concept of multiple server
> urls in WMC.
> > If you look at the schema for WMC 1.1, you will see that the
> > ServerType in the Layer has exactly one occurrence, and the
> > OnlineResource inside the ServerType also has exactly one
> occurrence.
> > So the issue in Format.WMC.v1 is that the content of
> layer.url will be
> > written to the OnlineResource's xlink attribute, which will
> produce an
> > invalid value (comma-separated list of urls) if the layer's
> url is an
> > array. The question is whether we just want to write the
> first url, or
> > an additional vendor extension value that stores all other urls.
> > Anyway, this deserves a ticket. Yves, if you are interested
> in getting
> > this fixed, we would appreciate if you could create this ticket and
> > maybe even provide a patch.
> > Regards,
> > Andreas.
> > Jacolin Yves wrote:
> > > Hello,
> > > I am using WMC OGC service to allow users to print my map with
> > > another design. Using multi-URL in OL give something like this in
> > > the WMC
> > > context: <Layer queryable="0" hidden="1">
> > >   <Server service="OGC:WMS" version="1.1.1">
> > >     <OnlineResource xlink:type="simple"
> > > xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="
> > > http://www.lpdipro.dev.local/tilecache/tilecache.py,
> > > http://www1.lpdipro.dev.local/tilecache/tilecache.py,
> > > http://www2.lpdipro.dev.local/tilecache/tilecache.py,
> > > http://www3.lpdipro.dev.local/tilecache/tilecache.py"/>
> > >   </Server>
> > >   <Name>ratp_ligne_metro</Name>
> > >   <Title>ratp_ligne_metro</Title>
> > > I added space between each url to improve readability.
> > > In OL code, after applying the context, the url of tile are:
> > > http://www3.lpdipro.dev.local/tilecache/tilecache.py?
> > > VERSION=1.1.1&FORMAT=image%2Fjpeg&
> > > LAYERS=cadastre&SERVICE=WMS&REQUEST=GetMap&
> > > STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&
> >SRS=EPSG%3A900913&BBOX=89321.71190000002,6171789.4407,245864.74580000
> > >003,
> > >6328332.4746& WIDTH=256&HEIGHT=256
> > > Again return line and space added for readability.
> > > Is it something known and how to correct this? Do I need
> to create a
> > > bug report, example?
> > > Thanks,
> > > Y.
> > > PS : I am going to test the new OL 2.8RC1 release.
> Yves Jacolin
> Ne demandez pas si vous pouvez contribuer, contribuer ! :)
> http://softlibre.gloobe.org
> Users mailing list
> http://openlayers.org/mailman/listinfo/users
