[OpenLayers-Users] displacement of google satellite data compared to google streetmap
Andreas Hocevar ahocevar at opengeo.org
Thu Apr 23 08:58:20 EDT 2009
this is a known issue, unfortunately without a good solution at the moment:
http://trac.openlayers.org/ticket/1797
http://trac.openlayers.org/ticket/2055
A workaround is to specify the map div's width and height in pixels.
Regards,
Andreas.
Joanne Cook wrote:
> Hi List,
> I have a map that I thought was all correctly set up to use spherical mercator, and all my data (which is all projected in 900913) is correctly displaying on either open streetmap or google streets data. However, when I add a google satellite or hybrid layer, the initial load of the map shows the satellite layer displaced several hundred miles to the west. If I switch to the google streets layer without any zooming or panning, the displacement disappears. If I then switch back to the google satellite layer, again with no zooming or panning, it appears in the correct place. Throughout all of this, my data layer has no displacement. Furthermore, since all of this is set within mapfish, with extjs used for side panels, if I minimise the side panel while the displacement is occurring it also removes the displacement. I'm using the svn versions of openlayers and mapfish.
> This is the code relating to setting up the map and layers:
> function createMap() {
> 	var options = {
> 		projection: new OpenLayers.Projection("EPSG:900913"),
>         displayProjection: new OpenLayers.Projection("EPSG:27700"),
>         units: "m",
>         maxResolution: 156543.0339,
>         maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
>                                                  20037508.34, 20037508.34)
> return new OpenLayers.Map('olmap',options);
> } //end createmap
> function addlayers(map){
> 	// define wms
> 	layer = new OpenLayers.Layer.WMS("OA Sites WMS", "http://geoserver.thehumanjourney.net:80/geoserver/wms?",
>                            {layers: 'oadigi:oasites', transparent: true, format: 'image/png', buffer:0},
>                             {isBaseLayer: false});
> 	// create Google Mercator layers
>             var gmap = new OpenLayers.Layer.Google(
>                 "Google Streets",
>                 {'sphericalMercator': true}
>             var gsat = new OpenLayers.Layer.Google(
>                 "Google Satellite",
>                 {type: G_SATELLITE_MAP, 'sphericalMercator': true, numZoomLevels: 22}
>             var ghyb = new OpenLayers.Layer.Google(
>                 "Google Hybrid",
>                 {type: G_HYBRID_MAP, 'sphericalMercator': true}
> 	// define pseudo-layer for highlighting selected features
> 	select = new OpenLayers.Layer.Vector("Selection",
> 		{protocol: new mapfish.Protocol.TriggerEventDecorator(protocol),
> 		strategies: [new mapfish.Strategy.ProtocolListener({append: true})],
> 		styleMap: new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),
> 		displayInLayerSwitcher: false});
> 	// add layers
> 	map.addLayers([layer, select, gmap, gsat, ghyb]);
> } //end addlayers
> function setMapCenter() {
> //define a new projection object so map can be centred using latlong
> 	var proj = new OpenLayers.Projection("EPSG:4326");
> 	var point = new OpenLayers.LonLat(-2.9, 53.6);
> 	this.setCenter(point.transform(proj, this.getProjectionObject()), 6);
> } //end setMapCenter
> I hope that's enough information for someone as it's hard for me to get this map accessible to the outside world yet.
> Many thanks
> Jo
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
