[OpenLayers-Users] displacement of google satellite data compared to google streetmap
RFeagin ryan.feagin at PEACHTREEGEOGRAPHICS.COM
Thu Apr 23 15:27:05 EDT 2009
as a really stupid work around, try catching the changebaselayer event.  Then
map.pan(-1,-1);  That worked for me with the popup issue I reported.
Andreas Hocevar-2 wrote:
> Hi,
> this is a known issue, unfortunately without a good solution at the
> moment:
> http://trac.openlayers.org/ticket/1797
> http://trac.openlayers.org/ticket/2055
> A workaround is to specify the map div's width and height in pixels.
> Regards,
> Andreas.
> Joanne Cook wrote:
>> Hi List,
>> I have a map that I thought was all correctly set up to use spherical
>> mercator, and all my data (which is all projected in 900913) is correctly
>> displaying on either open streetmap or google streets data. However, when
>> I add a google satellite or hybrid layer, the initial load of the map
>> shows the satellite layer displaced several hundred miles to the west. If
>> I switch to the google streets layer without any zooming or panning, the
>> displacement disappears. If I then switch back to the google satellite
>> layer, again with no zooming or panning, it appears in the correct place.
>> Throughout all of this, my data layer has no displacement. Furthermore,
>> since all of this is set within mapfish, with extjs used for side panels,
>> if I minimise the side panel while the displacement is occurring it also
>> removes the displacement. I'm using the svn versions of openlayers and
>> mapfish.
>> This is the code relating to setting up the map and layers:
>> function createMap() {
>> 	var options = {
>> 		projection: new OpenLayers.Projection("EPSG:900913"),
>>         displayProjection: new OpenLayers.Projection("EPSG:27700"),
>>         units: "m",
>>         maxResolution: 156543.0339,
>>         maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
>>                                                  20037508.34,
>> 20037508.34)
>> return new OpenLayers.Map('olmap',options);
>> } //end createmap
>> function addlayers(map){
>> 	// define wms
>> 	layer = new OpenLayers.Layer.WMS("OA Sites WMS",
>> "http://geoserver.thehumanjourney.net:80/geoserver/wms?",
>>                            {layers: 'oadigi:oasites', transparent: true,
>> format: 'image/png', buffer:0},
>>                             {isBaseLayer: false});
>> 	// create Google Mercator layers
>>             var gmap = new OpenLayers.Layer.Google(
>>                 "Google Streets",
>>                 {'sphericalMercator': true}
>>             var gsat = new OpenLayers.Layer.Google(
>>                 "Google Satellite",
>>                 {type: G_SATELLITE_MAP, 'sphericalMercator': true,
>> numZoomLevels: 22}
>>             var ghyb = new OpenLayers.Layer.Google(
>>                 "Google Hybrid",
>>                 {type: G_HYBRID_MAP, 'sphericalMercator': true}
>> 	// define pseudo-layer for highlighting selected features
>> 	select = new OpenLayers.Layer.Vector("Selection",
>> 		{protocol: new mapfish.Protocol.TriggerEventDecorator(protocol),
>> 		strategies: [new mapfish.Strategy.ProtocolListener({append: true})],
>> 		styleMap: new
>> OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),
>> 		displayInLayerSwitcher: false});
>> 	// add layers
>> 	map.addLayers([layer, select, gmap, gsat, ghyb]);
>> } //end addlayers
>> function setMapCenter() {
>> //define a new projection object so map can be centred using latlong
>> 	var proj = new OpenLayers.Projection("EPSG:4326");
>> 	var point = new OpenLayers.LonLat(-2.9, 53.6);
>> 	this.setCenter(point.transform(proj, this.getProjectionObject()), 6);
>> } //end setMapCenter
>> I hope that's enough information for someone as it's hard for me to get
>> this map accessible to the outside world yet.
>> Many thanks
>> Jo
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/displacement-of-google-satellite-data-compared-to-google-streetmap-tp2682471p2685412.html
