[OpenLayers-Users] EPSG:900913 Projection
José Carrizo c4rrizo at gmail.com
Thu Apr 23 19:27:48 EDT 2009
lol what a mistake!
Thanks so much for your help, i will got to upgrade it.
2009/4/23 Chris Holmes <cholmes at opengeo.org>
> You've got the wrong list, should ask this question on the Geoserver users
> list (geoserver-users at lists.sourceforge.net)
> But the answer to your question is to just upgrade GeoServer.  It was only
> fixed to handle 900913 in version 1.5.3, see
> http://jira.codehaus.org/browse/GEOS-1277
> That and later versions also ship with 900913, so you don't even have to
> add it to the epsg.properties file, it will work out of the box. Previous
> versions won't work even if you put the WKT right, because one of the
> parameters wasn't quite supported.
> best regards,
> Chris
> José Carrizo wrote:
>> Hi everybody,
>> I'm trying to add EPSG:900913 projection definition in geoserver1.5.0
>> typing the following line into epsg.properties file:
>> 900913=PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World
>> Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563,
>> AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich",
>> 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
>> AUTHORITY["EPSG","4326"]], PROJECTION["Mercator (1SP)",
>> AUTHORITY["EPSG","9804"]], PARAMETER["semi_major", 6378137.0],
>> PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0],
>> PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0],
>> PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m",
>> 1.0],  AUTHORITY["EPSG","900913"]]
>> and when I look at srsHelp.do itsn't listed, and console shows the
>> following message:
>> WARNING: Issues converting EPSG:900913. No code "EPSG:900913" from
>> authority "European Petroleum Survey Group" found for object of type
>> "CoordinateReferenceSystem".
>> I don't have idea about what's happening :S
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Chris Holmes
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090423/acaafb05/attachment.html
