[OpenLayers-Users] change projection layer dynamically
Roald de Wit
roald.dewit at lisasoft.com
Fri Apr 24 22:45:04 EDT 2009
Hi Toni,
OpenLayers cannot combine WMS layers with different projections nor can
it easily switch projections, certainly not on the fly based on the
region you are viewing!
What I advise you to do is the following if you have no control over
these WMS servers and cannot have them serve all images in one
projection: have MapServer act as a reprojecting proxy for you.
MapServer can act as a WMS client and reproject the imagery into the
projection you want. This page describes how to do this: [1].
If you need more assistance with setting up or configuring MapServer I
advise you to ask their mailing list.
I hope this helps.
Regards, Roald
[1] http://mapserver.org/ogc/wms_client.html
toni hernández wrote:
> hi,
> I have a map that gets some WMS layers from two different servers all
> over spain.
> There is one wms server that needs a concrete epsg parameter (23029,
> 23030 or 23031) depending on the zone of spain. This server does not
> accept epsg:4326.
> So dependig on the zone of the map that is being displaid I need to
> change the WMS layer projection.
> is this possible?
