[OpenLayers-Users] change projection layer dynamically
Roald de Wit
roald.dewit at lisasoft.com
Sun Apr 26 07:00:13 EDT 2009
Hi Toni,
I tried the WMS service but could not get *any* useful imagery out of it
(not with OL nor with uDIG). Have you got an OL configuration that zooms
to extents that I can use to test my config in MapServer, preferably
with 3 extents: one for every region?
Cheers, Roald
toni hernández wrote:
> hi,
> I hadn't thought of that.
> So far I have tried with one layer. But maybe I could also try
> defining three different layers with three different projections.
> The valid projections are: epsg:23029 (east), epsg:23030 (interior),
> epsg:23031 (west)
> and This is the layer
> var sigpaclayer = new OpenLayers.Layer.WMS(
> "Sigpac",
> "http://wms.mapa.es/wms/wms.aspx",
> {layers: 'ORTOFOTOS', transparent: "true", format:
> "image/png"} , buffer: 0, minScale:8607}
> thanks for trying.
> 2009/4/26 Roald de Wit <roald.dewit at lisasoft.com
> <mailto:roald.dewit at lisasoft.com>>
> Hi,
> I'm trying to find out if it is one layer (or layername) that you
> request or different layers (or layer names) for different zones.
> If it is the former, I would have no idea how to solve your
> problem. If it is the latter, the MapServer solution would be
> perfect. You would then define 3 layers in MapServer (it was three
> zones, wasn't it?) for every zone, each with their own projection.
> And in OpenLayers, you would create 1 WMS layer that requests
> those 3 layers from MapServer as if it was one layer. MapServer
> would do the reprojection for you.
> If the WMS server is public and you can give me the URL and the
> layers you need, I'd be happy to try it out for you.
> Cheers, Roald
> Hi,
> I'am no sure I understand the question.
> The WMS server renders just one layer for a very close scale.
> From 5000 and lower. Depending on the zone you want to be
> drawn you have to send the correct epsg. Otherwise no image is
> drawn.
> is that where you where asking?
