[OpenLayers-Users] Selecting multiple features in the same point
Manuel Albela Miranda manuel.albela at gmail.com
Fri Aug 14 02:58:00 EDT 2009
Hi again!
Thank you very much Ivan and Jerome for you help. Clusters work great!, just
what I needed.
Best regards, and thank you again!
Manu
On Thu, Aug 13, 2009 at 1:43 PM, Jerome Freyre <jerome.freyre at hispeed.ch>wrote:
> Hi Manuel,
> Another way should be the use of the cluster strategy.
> If you activate the strategy, all closest points are transform in one
> feature called cluster. And the cluster contains points so you can easily
> display informations about your points.
> http://openlayers.org/dev/examples/strategy-cluster.html
> Manuel Albela Miranda wrote:
> > Hi everybody!,
> > I have one GML layer where some of the points are in the same location,
> so
> > I'm wondering if it's possible to get all the features that are at that
> > location when you click on it by using the SelectFeature control or if
> > there
> > is another way to do that.
> > Thank you very much in advance.
> > Manu.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> http://n2.nabble.com/Selecting-multiple-features-in-the-same-point-tp3436892p3437344.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090814/18c101b7/attachment.html
