[OpenLayers-Users] Selecting multiple features in the same point
Ivan Grcic igrcic at gmail.com
Fri Aug 14 03:08:02 EDT 2009
Yes, cluster is pretty nice feature to have. I advise to use it with
BBOX strategy, especially if u have lots of features!
Cheers
On Fri, Aug 14, 2009 at 8:58 AM, Manuel Albela
Miranda<manuel.albela at gmail.com> wrote:
> Hi again!
> Thank you very much Ivan and Jerome for you help. Clusters work great!, just
> what I needed.
> Best regards, and thank you again!
> Manu
> On Thu, Aug 13, 2009 at 1:43 PM, Jerome Freyre <jerome.freyre at hispeed.ch>
> wrote:
>> Hi Manuel,
>> Another way should be the use of the cluster strategy.
>> If you activate the strategy, all closest points are transform in one
>> feature called cluster. And the cluster contains points so you can easily
>> display informations about your points.
>> http://openlayers.org/dev/examples/strategy-cluster.html
>> Manuel Albela Miranda wrote:
>> > Hi everybody!,
>> > I have one GML layer where some of the points are in the same location,
>> > so
>> > I'm wondering if it's possible to get all the features that are at that
>> > location when you click on it by using the SelectFeature control or if
>> > there
>> > is another way to do that.
>> > Thank you very much in advance.
>> > Manu.
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> View this message in context:
>> http://n2.nabble.com/Selecting-multiple-features-in-the-same-point-tp3436892p3437344.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
Ivan Grcic
