[OpenLayers-Users] Transforming from Gauß-Krüger to UTM
Max Stephan x.zam at gmx.net
Thu Aug 20 08:32:56 EDT 2009
Hi everyone!
I´m having problems with transforming my coordinates which are
Gauß-Krüger/Zone 4 (Germany). In order to add them to my map they should be
EPSG:4326 or EPSG:900913 (the google-EPSG). I tried to convert them wire the
method offered by OpenLayers (myCoords.transform(presentEPSG,targetEPSG). As
present EPSG I use EPSG:31486 (I guess that should be the right one) and as
targetEPSG I use EPSG:900913.
The code looks like this:
markerCoord.transform(new OpenLayers.Projection("EPSG:31468"),new
OpenLayers.Projection("EPSG:900913"));
The input coordinates are for example 4426360 E 5489583 N, the output to
EPSG:900913 should be something in the area of 1220000 E 6360000 N. But when
I try transforming it the result is always exactly the same as the input
was.
Any ideas how to solve this problem?
Greets and thx in advance
Max Stephan
View this message in context: http://n2.nabble.com/Transforming-from-Gau-Kruger-to-UTM-tp3478735p3478735.html
