[OpenLayers-Users] Transforming from Gauß-Krüger to UTM
Marc Jansen jansen at terrestris.de
Thu Aug 20 08:49:12 EDT 2009
Are the respective proj.js files loaded?
-- marc
Max Stephan schrieb:
> Hi everyone!
> I´m having problems with transforming my coordinates which are
> Gauß-Krüger/Zone 4 (Germany). In order to add them to my map they should be
> EPSG:4326 or EPSG:900913 (the google-EPSG). I tried to convert them wire the
> method offered by OpenLayers (myCoords.transform(presentEPSG,targetEPSG). As
> present EPSG I use EPSG:31486 (I guess that should be the right one) and as
> targetEPSG I use EPSG:900913.
> The code looks like this:
> markerCoord.transform(new OpenLayers.Projection("EPSG:31468"),new
> OpenLayers.Projection("EPSG:900913"));
> The input coordinates are for example 4426360 E 5489583 N, the output to
> EPSG:900913 should be something in the area of 1220000 E 6360000 N. But when
> I try transforming it the result is always exactly the same as the input
> was.
> Any ideas how to solve this problem?
> Greets and thx in advance
> Max Stephan
