[OpenLayers-Users] Transforming from Gauß-Krüger to UTM
Max Stephan x.zam at gmx.net
Thu Aug 20 09:10:10 EDT 2009
Hi Marc,
thank you for the hint. I had already loaded the proj.js files via <script
src="lib/def/EPSG31468.js"></script>. I also have added the definition for
EPSG:31468 in the proj4js-folder. The one thing I forgot is to change the
folder to where those files are located. Now that I´ve done that it works.
so, thx again
Max Stephan
Marc Jansen-2 wrote:
> Are the respective proj.js files loaded?
> -- marc
> Max Stephan schrieb:
>> Hi everyone!
>> I´m having problems with transforming my coordinates which are
>> Gauß-Krüger/Zone 4 (Germany). In order to add them to my map they should
>> be
>> EPSG:4326 or EPSG:900913 (the google-EPSG). I tried to convert them wire
>> the
>> method offered by OpenLayers (myCoords.transform(presentEPSG,targetEPSG).
>> As
>> present EPSG I use EPSG:31486 (I guess that should be the right one) and
>> as
>> targetEPSG I use EPSG:900913.
>> The code looks like this:
>> markerCoord.transform(new OpenLayers.Projection("EPSG:31468"),new
>> OpenLayers.Projection("EPSG:900913"));
>> The input coordinates are for example 4426360 E 5489583 N, the output to
>> EPSG:900913 should be something in the area of 1220000 E 6360000 N. But
>> when
>> I try transforming it the result is always exactly the same as the input
>> was.
>> Any ideas how to solve this problem?
>> Greets and thx in advance
>> Max Stephan
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Transforming-from-Gau-Kruger-to-UTM-tp3478735p3478919.html
