[OpenLayers-Users] How Print openlayer Maps into pdf documents
Kris Geusebroek
kgeusebroek at xebia.com
Tue Dec 1 10:15:28 EST 2009
Well the style could be because you don't provide a style in the url, this way geoserver uses the default style specified in the layer configuration. So you might want to add the layer style also
And the resolution might be because of the width and height setting wich I think is smaller then the openlayers client width etc.
Cheers Kris
-----Original Message-----
Sent: Tuesday, December 01, 2009 3:30 PM
To: Kris Geusebroek
Cc: users at openlayers.org
Subject: [OpenLayers-Users] How Print openlayer Maps into pdf documents
Kris,
I continue with this problems, I make one function for a print to pdf but,
the map is not similar ,for example the point icons that show in pdf is poi
style Instead my style , and also the resolution in pdf document is very
low.
¿ How resolve this problems?
This is my function
function Imprimir()
var ext = map.getExtent();
var minx = ext.left;
var miny = ext.bottom;
var maxx = ext.right;
var maxy = ext.top;
var Cadena =
"http://urano:3128/geoserver/wms?bbox="+minx+","+miny+","+maxx+","+maxy+"&styles=&Format=application/pdf&request=GetMap&version=1.1.1&layers=";
for(var i = 0; i < map.layers.length; i++)
{if(i < map.layers.length - 1)
Cadena += map.layers[i].params.LAYERS+",";
else
Cadena += map.layers[i].params.LAYERS;
}Cadena += "&width=400&height=300&srs=EPSG:4267";
window.open(Cadena);
thanks ,
Regards , Salas
----- Original Message -----
To: "Kris Geusebroek" <kgeusebroek at xebia.com>; <users at openlayers.org>
Sent: Thursday, September 03, 2009 12:22 PM
Subject: Re: [OpenLayers-Users] How Print openlayer Maps into pdf documents
Thanks, Cheers
Francisco Salas
To: "Alexandre Dube" <adube at mapgears.com>; "fsalas" <fsalas at geocuba.cu>
Cc: <users at openlayers.org>
Sent: Wednesday, September 02, 2009 3:34 PM
Subject: RE: [OpenLayers-Users] How Print openlayer Maps into pdf documents
If you are using geoserver you can create a wms request with format
application/pdf et volia!
Cheers Kris
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Alexandre Dube
Sent: Wednesday, September 02, 2009 5:29 PM
To: fsalas
Did you read http://trac.openlayers.org/wiki/Printing ?
About eh ezpdf class extension, are you talking about this :
http://www.ros.co.nz/pdf/ ? If so, that's the lib I used with
phpMapScript to accomplish some printing, but it supports WMS only and I
use Ext to make my form. So take this example as a proof of concept
only. See at :
http://dev4.mapgears.com/wmsprint/
MapFish has a much more better printing tool and it supports Vector
features printing.
Best of luck,
Alexandre
fsalas wrote:
> Hi all,
> I'm trying to print the current image maps into pdf documents
> using the *EZPDF Class Extension,* but don´t work.
> some body know how i cant implement this.
> Thanks ,
> salas
> ___________________________________
> Dirección de Comunicaciones
> Grupo Empresarial GEOCUBA
> Este mensaje esta libre de virus.
> Revisado por Kaspersky Antivirus
> Definition count: 2365875 Definition date: 8/11/2009 SecurityPlus
> version: 3.0.5
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
Users mailing list
Definition count: 2492726
Definition date: 9/3/2009
SecurityPlus version: 3.0.5
Users mailing list
