[OpenLayers-Users] WFS called with xmlhttprequest in different domain
JuKiM rifins at gmail.com
Tue Dec 1 10:03:04 EST 2009
I have a web app served by IIS that calls WFS in geoserver. I've read that a
proxy is needed to do this, but everything that I'm finding is for Apache..
To resolve this, I create a page called test.aspx that acts as a ProxyHost
(test.aspx?url=) which is called and loads the URL passed as querystring.
This works with GET and POST, but my problem is that when the result is
returned to the client, after the XML there are the html tags appended.
To call the GeoServer WFS I do the next code in test.aspx.vb:
            Dim wsResponse As XmlDocument = New XmlDocument()
            Dim url As String = Request.QueryString("url")
            wsResponse.Load(url)
            Dim XMLDocument As String = wsResponse.InnerXml
            Response.Clear()
            Response.ContentType = "text/xml"
            Response.Write(XMLDocument)
And the result in client side is:
<?xml version="1.0" encoding="UTF-8"?><wfs:FeatureCollection> [...]
</wfs:FeatureCollection>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "
http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
<head><title>
</title></head>
<body>
    <form name="form1" method="post"
action="test.aspx?url=http%3a%2f%2flocalhost%3a8080%2fgeoserver%2fwfs"
id="form1">
<div>
<input type="hidden" name="__VIEWSTATE" id="__VIEWSTATE"
value="/wEPDwCHFbQDoeTY2CHFbQDoCHFbQDoedgOjCHFbQDoeOGKuXA9" />
</div>
    <div>
    </div>
    </form>
</body>
</html>
Is there any way to avoid the adding of html tags and return only the XML?
Thanks!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091201/369a91fd/attachment.html
