[OpenLayers-Users] Array of url's not working with WFS protocol
Bart van den Eijnden bartvde at osgis.nl
Mon Dec 7 08:53:51 EST 2009
Hi Kris,
that actually slipped my mind when I said patches welcome :-)
The only way I see is to use an iframe hack instead of real XHR. The reason I also have been wanting to look into this is some security issues in IE with ActiveX, not all of my customers had ActiveX enabled, or somehow the XMLHttp one was treated as an untrusted ActiveX.
Best regards,
Bart
On Dec 7, 2009, at 8:45 AM, Kris Geusebroek wrote:
> Hi,
> Just to inform you the reason why I need this:
> I use multiple vector layer with WMS protocol to track vehicles around
> the country. I refresh the layers every 5 seconds so I generate a lot of
> requests to the same domain.
> Since internet explorer only fires 2 requests to the same domain in
> parallel I wanted to configure my DNS to have multiple domain names for
> the same ip address so I could trick IE into doing more then 2 requests
> at a time.
> But since the subdomains are not allowed in XHR I'm kind of stuck right
> now.
> Anyone have a suggestion for me?
> Cheers Kris
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Friday, December 04, 2009 4:54 PM
> To: Kris Geusebroek
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Array of url's not working with WFS
> protocol
> On Fri, Dec 04, 2009 at 03:38:36PM +0100, Kris Geusebroek wrote:
>> I tried to create a patch but it isn't working.
>> I patched Request.js to select a url out of an Array (just like the
>> httpRequest class) but I'm running into crossdomain issue with XHR
>> Even on only a subdomain difference, IE and firefox throw an exception
> Different subdomains are still violations of the Same Origin Policy.
> The browser can not request data from different subdomains (and I can't
> imagine a way in which this is useful other than that; using a proxy
> just
> makes the local proxy your bottleneck.)
> -- Chris
>> Any hints on how to overcome this or is it impossible
>> Cheers KRis
>> From: users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org]
>> On Behalf Of Kris Geusebroek
>> Sent: Wednesday, December 02, 2009 11:59 AM
>> To: users at openlayers.org
>> Subject: [OpenLayers-Users] Array of url's not working with WFS
> protocol
>> Am i right that supplying a array of urls to  a wfs protocol is not
>> working like with a layer?
>> If so I will try tomorrow to create a patch to provide this
>> functionality
>> Cheers Kris
>> Met vriendelijke groet, Kind regards,
>> Kristiaan Geusebroek
>> Consultant
>> Email: kgeusebroek at xebia.com <mailto:kgeusebroek at xebia.com>
>> Tel: +31 (0)35 538 1921
>> Fax: +31 (0)35 538 1922
>> Mobiel: +31 (0)6 3069 7223
>> Utrechtseweg 49
>> 1213 TL Hilversum
>> The Netherlands
>> http://www.xebia.com <http://www.xebia.com/>
>> Xebia Blog: http://blog.xebia.com/ <http://blog.xebia.com/>
>> Xebia Podcast: http://podcast.xebia.com/ <http://podcast.xebia.com/>
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
