[OpenLayers-Users] OpenLayers.Feature.Vector hover + click event
Ivan Grcic igrcic at gmail.com
Thu Dec 10 07:18:11 EST 2009
selectFeature doesnt have click event:
http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Control/SelectFeature-js.html#OpenLayers.Control.SelectFeature.EVENT_TYPES
Defining callback for click should work though
OpenLayers.Control.SelectFeature([vector1,vector2],{
           hover : true,
           highlightOnly : false,
            callbacks: {
                click : function (feat){
                     // do what you want here
Cheers
On Thu, Dec 10, 2009 at 12:34 PM, _greg_ <gstopar at gmail.com> wrote:
> Hi all
> Is possible to recive click events and have hover turned on with
> OpenLayers.Control.SelectFeature ?
> I have two vector layers. One for draggable features and another for not
> draggable.
> I want to be able to select features from both layers (I'm using OL-2.8).
> Feature hover works fine and  also featureselected events are ok. But I do
> not get click events.
> My code is :
> var vector1 = new OpenLayers.Layer.Vector("NotDraggableMarkers",{
>            isBaseLayer : false,
>            rendererOptions : {
>                yOrdering : true
>            styleMap : this.getMarkerStyleMap()
>        var vector2 = new OpenLayers.Layer.Vector("DraggableMarkers",{
>            rendererOptions : {
>                yOrdering : true
>        this.map.addLayers([vector1,vector2]);
>        var dragFeature = new OpenLayers.Control.DragFeature(vector2);
>        this.map.addControl(dragFeature);
>        dragFeature.activate();
>        var select = new
>            hover : true,
>        this.map.addControl(select);
>        select.events.on({
>            "featurehighlighted" : this.high,
>            "click" : this.click
> Is there any way to do this ? Any ideas ?
> Thanks.
> View this message in context: http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4144872.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
