[OpenLayers-Users] OpenLayers.Feature.Vector hover + click event
_greg_ gstopar at gmail.com
Thu Dec 10 07:30:49 EST 2009
Thanks for your answer.
Yes. I've tried this and here is what happens:
1. I click first on draggable feature => click event occurs => cool
2. Click on second not draggable feature => click event occurs => cool
3. Click again on first feature => click event is not dispatched.
Any ideas ?
Ivan Grcic-2 wrote:
> Hi,
> selectFeature doesnt have click event:
> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Control/SelectFeature-js.html#OpenLayers.Control.SelectFeature.EVENT_TYPES
> Defining callback for click should work though
> OpenLayers.Control.SelectFeature([vector1,vector2],{
>            hover : true,
>            highlightOnly : false,
>             callbacks: {
>                 click : function (feat){
>                      // do what you want here
> Cheers
> On Thu, Dec 10, 2009 at 12:34 PM, _greg_ <gstopar at gmail.com> wrote:
>> Hi all
>> Is possible to recive click events and have hover turned on with
>> OpenLayers.Control.SelectFeature ?
>> I have two vector layers. One for draggable features and another for not
>> draggable.
>> I want to be able to select features from both layers (I'm using OL-2.8).
>> Feature hover works fine and  also featureselected events are ok. But I
>> do
>> not get click events.
>> My code is :
>> var vector1 = new OpenLayers.Layer.Vector("NotDraggableMarkers",{
>>            isBaseLayer : false,
>>            rendererOptions : {
>>                yOrdering : true
>>            styleMap : this.getMarkerStyleMap()
>>        var vector2 = new OpenLayers.Layer.Vector("DraggableMarkers",{
>>            rendererOptions : {
>>                yOrdering : true
>>        this.map.addLayers([vector1,vector2]);
>>        var dragFeature = new OpenLayers.Control.DragFeature(vector2);
>>        this.map.addControl(dragFeature);
>>        dragFeature.activate();
>>        var select = new
>>            hover : true,
>>        this.map.addControl(select);
>>        select.events.on({
>>            "featurehighlighted" : this.high,
>>            "click" : this.click
>> Is there any way to do this ? Any ideas ?
>> Thanks.
>> View this message in context:
>> http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4144872.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
> Users mailing list
View this message in context: http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4145073.html
