[OpenLayers-Users] OpenLayers.Feature.Vector hover + click event
Ivan Grcic igrcic at gmail.com
Thu Dec 10 08:41:14 EST 2009
Hi, so your first feature is allready selected when you click on it second time?
On Thu, Dec 10, 2009 at 1:30 PM, _greg_ <gstopar at gmail.com> wrote:
> Hi,
> Thanks for your answer.
> Yes. I've tried this and here is what happens:
> 1. I click first on draggable feature => click event occurs => cool
> 2. Click on second not draggable feature => click event occurs => cool
> 3. Click again on first feature => click event is not dispatched.
> Any ideas ?
> Ivan Grcic-2 wrote:
>> Hi,
>> selectFeature doesnt have click event:
>> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Control/SelectFeature-js.html#OpenLayers.Control.SelectFeature.EVENT_TYPES
>> Defining callback for click should work though
>> OpenLayers.Control.SelectFeature([vector1,vector2],{
>>            hover : true,
>>            highlightOnly : false,
>>             callbacks: {
>>                 click : function (feat){
>>                      // do what you want here
>> Cheers
>> On Thu, Dec 10, 2009 at 12:34 PM, _greg_ <gstopar at gmail.com> wrote:
>>> Hi all
>>> Is possible to recive click events and have hover turned on with
>>> OpenLayers.Control.SelectFeature ?
>>> I have two vector layers. One for draggable features and another for not
>>> draggable.
>>> I want to be able to select features from both layers (I'm using OL-2.8).
>>> Feature hover works fine and  also featureselected events are ok. But I
>>> do
>>> not get click events.
>>> My code is :
>>> var vector1 = new OpenLayers.Layer.Vector("NotDraggableMarkers",{
>>>            isBaseLayer : false,
>>>            rendererOptions : {
>>>                yOrdering : true
>>>            styleMap : this.getMarkerStyleMap()
>>>        var vector2 = new OpenLayers.Layer.Vector("DraggableMarkers",{
>>>            rendererOptions : {
>>>                yOrdering : true
>>>        this.map.addLayers([vector1,vector2]);
>>>        var dragFeature = new OpenLayers.Control.DragFeature(vector2);
>>>        this.map.addControl(dragFeature);
>>>        dragFeature.activate();
>>>        var select = new
>>>            hover : true,
>>>        this.map.addControl(select);
>>>        select.events.on({
>>>            "featurehighlighted" : this.high,
>>>            "click" : this.click
>>> Is there any way to do this ? Any ideas ?
>>> Thanks.
>>> View this message in context:
>>> http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4144872.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Ivan Grcic
>> Users mailing list
> View this message in context: http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4145073.html
> Users mailing list
Ivan Grcic
