[OpenLayers-Users] OpenLayers.Feature.Vector hover + click event
Ivan Grcic igrcic at gmail.com
Thu Dec 10 08:45:33 EST 2009
BTW you might also investigate this a little bit:
http://dev.openlayers.org/sandbox/tschaub/select/examples/feature-events.html
On Thu, Dec 10, 2009 at 2:41 PM, Ivan Grcic <igrcic at gmail.com> wrote:
> Hi, so your first feature is allready selected when you click on it second time?
> On Thu, Dec 10, 2009 at 1:30 PM, _greg_ <gstopar at gmail.com> wrote:
>> Hi,
>> Thanks for your answer.
>> Yes. I've tried this and here is what happens:
>> 1. I click first on draggable feature => click event occurs => cool
>> 2. Click on second not draggable feature => click event occurs => cool
>> 3. Click again on first feature => click event is not dispatched.
>> Any ideas ?
>> Ivan Grcic-2 wrote:
>>> Hi,
>>> selectFeature doesnt have click event:
>>> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Control/SelectFeature-js.html#OpenLayers.Control.SelectFeature.EVENT_TYPES
>>> Defining callback for click should work though
>>> OpenLayers.Control.SelectFeature([vector1,vector2],{
>>>            hover : true,
>>>            highlightOnly : false,
>>>             callbacks: {
>>>                 click : function (feat){
>>>                      // do what you want here
>>> Cheers
>>> On Thu, Dec 10, 2009 at 12:34 PM, _greg_ <gstopar at gmail.com> wrote:
>>>> Hi all
>>>> Is possible to recive click events and have hover turned on with
>>>> OpenLayers.Control.SelectFeature ?
>>>> I have two vector layers. One for draggable features and another for not
>>>> draggable.
>>>> I want to be able to select features from both layers (I'm using OL-2.8).
>>>> Feature hover works fine and  also featureselected events are ok. But I
>>>> do
>>>> not get click events.
>>>> My code is :
>>>> var vector1 = new OpenLayers.Layer.Vector("NotDraggableMarkers",{
>>>>            isBaseLayer : false,
>>>>            rendererOptions : {
>>>>                yOrdering : true
>>>>            styleMap : this.getMarkerStyleMap()
>>>>        var vector2 = new OpenLayers.Layer.Vector("DraggableMarkers",{
>>>>            rendererOptions : {
>>>>                yOrdering : true
>>>>        this.map.addLayers([vector1,vector2]);
>>>>        var dragFeature = new OpenLayers.Control.DragFeature(vector2);
>>>>        this.map.addControl(dragFeature);
>>>>        dragFeature.activate();
>>>>        var select = new
>>>>            hover : true,
>>>>        this.map.addControl(select);
>>>>        select.events.on({
>>>>            "featurehighlighted" : this.high,
>>>>            "click" : this.click
>>>> Is there any way to do this ? Any ideas ?
>>>> Thanks.
>>>> View this message in context:
>>>> http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4144872.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Ivan Grcic
>>> Users mailing list
>> View this message in context: http://n2.nabble.com/OpenLayers-Feature-Vector-hover-click-event-tp4144872p4145073.html
>> Users mailing list
> Ivan Grcic
Ivan Grcic
