[OpenLayers-Users] Buffering and resizing a point
Andreas Hocevar
ahocevar at opengeo.org
Thu Dec 17 05:44:22 EST 2009
why so complicated?
Ivan pointed you to the right way to do it. If you look at it, you see a
context with a getType function. In this function, you can return the
desired point radius. If you have your radius in map units, just do the
following:
return radiusInMapUnits / map.getResolution();
Regards,
Andreas.
On 2009-12-17 11:15, Mehmet Sirin wrote:
> hi, there you have the same problem: point-vectors stays as they are
> -without stretching/resizing.
> i just find the solution:
> function createCircle(lat, lon, radius){
> polygonLayer.removeFeatures(polygonLayer.features);
> var style = {
> fillColor: '#ff0000',
> strokeWidth: 1,
> pointRadius: radius, // in map coordinates
> var point = new OpenLayers.Geometry.Point(lat, lon);
> var polygonFeature =
> OpenLayers.Geometry.Polygon.createRegularPolygon(point,radius,30,0);
> var feature = new
> OpenLayers.Feature.Vector(polygonFeature,null, style);
> polygonLayer.addFeatures([feature]);
> polygonLayer.setOpacity(0.5);
> 2009/12/17 Ivan Grcic <igrcic at gmail.com <mailto:igrcic at gmail.com>>
> Hi, cant you make something like this:
> http://openlayers.org/dev/examples/styles-context.html
> On Thu, Dec 17, 2009 at 10:34 AM, Mehmet Sirin
> <m.sirin07 at googlemail.com <mailto:m.sirin07 at googlemail.com>> wrote:
> > hi,
> > since there isn't a buffer function integrated in openlayers i
> have to find
> > other ways to simulate buffering a point and displaying it:
> > function pointBuffer(lat, lon, radius,color){
> > var style = {
> > strokeWidth: 1,
> > pointRadius: radius, // in pixels
> > var feature = new
> OpenLayers.Feature.Vector(point,null,
> > style);
> > var lonlat1=new
> > OpenLayers.LonLat(parseInt(radius),0);
> > var lonlat2=new
> > OpenLayers.LonLat(parseInt(radius*2),0);
> > var
> > pixel1=map.getLayerPxFromLonLat(lonlat1);
> > var
> > pixel2=map.getLayerPxFromLonLat(lonlat2);
> > var dist=
> > Math.abs(parseInt(pixel2.x)-parseInt(pixel1.x));
> > createCircle(x,y,dist);
> > It works fine, but now the problem:
> > When zooming in or out the point feature won't resize -that
> means it does
> > not changes. the pixel size/radius is the same in every zoom level.
> > for solving this, i thought of creating a linearring and then a
> polygon, of
> > which i know that will automatically resize with zooming.
> > i tried:
> > var linearRing = new OpenLayers.Geometry.LinearRing(point);
> //just one point
> > var polygonFeature = new OpenLayers.Feature.Vector(
> > new OpenLayers.Geometry.Polygon([linearRing]),null, style);
> > but seems not to work..
> > anybody can help?
> > regards
> > m.sirin
> > Users mailing list
> > Users at openlayers.org <mailto:Users at openlayers.org>
> > http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
