[OpenLayers-Users] Buffering and resizing a point
Ivan Grcic igrcic at gmail.com
Thu Dec 17 06:00:07 EST 2009
In this way when you zoom in the map, your features will be huge.
Except that is the behaviour you want to achieve...
cheers
On Thu, Dec 17, 2009 at 11:44 AM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> why so complicated?
> Ivan pointed you to the right way to do it. If you look at it, you see a
> context with a getType function. In this function, you can return the
> desired point radius. If you have your radius in map units, just do the
> following:
> return radiusInMapUnits / map.getResolution();
> Regards,
> Andreas.
> On 2009-12-17 11:15, Mehmet Sirin wrote:
>> hi, there you have the same problem: point-vectors stays as they are
>> -without stretching/resizing.
>> i just find the solution:
>>           function createCircle(lat, lon, radius){
>>            polygonLayer.removeFeatures(polygonLayer.features);
>>                 var style = {
>>                     fillColor: '#ff0000',
>>                     strokeWidth: 1,
>>                     pointRadius: radius,  // in map coordinates
>>                var point = new OpenLayers.Geometry.Point(lat, lon);
>>                var polygonFeature =
>> OpenLayers.Geometry.Polygon.createRegularPolygon(point,radius,30,0);
>>                var feature = new
>> OpenLayers.Feature.Vector(polygonFeature,null, style);
>>                 polygonLayer.addFeatures([feature]);
>>                 polygonLayer.setOpacity(0.5);
>> 2009/12/17 Ivan Grcic <igrcic at gmail.com <mailto:igrcic at gmail.com>>
>>     Hi, cant you make something like this:
>>     http://openlayers.org/dev/examples/styles-context.html
>>     On Thu, Dec 17, 2009 at 10:34 AM, Mehmet Sirin
>>     <m.sirin07 at googlemail.com <mailto:m.sirin07 at googlemail.com>> wrote:
>>     > hi,
>>     > since there isn't a buffer function integrated in openlayers i
>>     have to find
>>     > other ways to simulate buffering a point and displaying it:
>>     >  function pointBuffer(lat, lon, radius,color){
>>     >            polygonLayer.removeFeatures(polygonLayer.features);
>>     >                 var style = {
>>     >                     fillColor: '#ff0000',
>>     >                     strokeWidth: 1,
>>     >                     pointRadius: radius,  // in pixels
>>     >                 var point = new OpenLayers.Geometry.Point(lat, lon);
>>     >                 var feature = new
>>     OpenLayers.Feature.Vector(point,null,
>>     > style);
>>     >                 polygonLayer.addFeatures([feature]);
>>     >                 polygonLayer.setOpacity(0.5);
>>     >                                  var lonlat1=new
>>     > OpenLayers.LonLat(parseInt(radius),0);
>>     >                                  var lonlat2=new
>>     > OpenLayers.LonLat(parseInt(radius*2),0);
>>     >                                  var
>>     > pixel1=map.getLayerPxFromLonLat(lonlat1);
>>     >                                  var
>>     > pixel2=map.getLayerPxFromLonLat(lonlat2);
>>     >                                  var dist=
>>     > Math.abs(parseInt(pixel2.x)-parseInt(pixel1.x));
>>     >                                  createCircle(x,y,dist);
>>     > It works fine, but now the problem:
>>     > When zooming in or out the point feature won't resize -that
>>     means it does
>>     > not changes. the pixel size/radius is the same in every zoom level.
>>     > for solving this, i thought of creating a linearring and then a
>>     polygon, of
>>     > which i know that will automatically resize with zooming.
>>     > i tried:
>>     > var linearRing = new OpenLayers.Geometry.LinearRing(point);
>>     //just one point
>>     > var polygonFeature = new OpenLayers.Feature.Vector(
>>     >  new OpenLayers.Geometry.Polygon([linearRing]),null, style);
>>     > but seems not to work..
>>     > anybody can help?
>>     > regards
>>     > m.sirin
>>     > _______________________________________________
>>     > Users mailing list
>>     > Users at openlayers.org <mailto:Users at openlayers.org>
>>     > http://openlayers.org/mailman/listinfo/users
>>     Ivan Grcic
>> Users mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
Ivan Grcic
