[OpenLayers-Users] combining drag and select layers on one map - drag not working
mehmet m.sirin07 at googlemail.com
Thu Dec 17 19:57:06 EST 2009
hi,
I intend to do the same and experienced too that this is not possible.
Is there really no solution to this issue? No one has an idea to solve this
problem?
I need to do this, because on layer1 i got some draggable marker and on
layer2 wfs-features with pop-ups.
regards
m.sirin
Eric Lemoine-2-2 wrote:
> Hi
> As you've noticed, since recently, you can have a select feature
> control work with multiple vector layers. Yet, Andreas or others will
> correct me if I'm wrong, your use case isn't covered - you cannot have
> a drag control, working on one layer, and a select control working, on
> another layer, activated at the same time. Only the layer(s) of the
> control activated last will be interactive.
> Eric
> 2009/4/4, Charlie DeTar <chazen at gmail.com>:
>> Hi,
>> I'm trying to construct a map that contains a draggable marker in
>> addition to features that, when clicked, produce a popup.  Reading the
>> docs and examples, it seemed that the way to do this is to use a vector
>> layer with a DragFeature control, and an additional vector layer with a
>> SelectFeature control to handle popups.  However, I'm finding that once
>> the SelectFeature control has been activated, the DragFeature no longer
>> works -- dragging only pans the map.  I'm testing this using Firefox 3.0
>> under Linux with stable OpenLayers (2.7).
>> I've been trying to figure out if this has something to do with event
>> propagation, and have tried setting stopUp and stopDown to false for
>> both the dragFeature and selectFeature handlers to no effect.  Calling
>> dragFeature.handlers.feature.moveLayerToTop() makes the drag handler
>> work, but kills the selectFeature, regardless of what order the layers
>> are added.  Though I would like both layers working simultaneously, I
>> did find that disabling the selectable layer using the LayerSwitcher
>> made the drag control work again in stable 2.7, but in the latest SVN
>> R9190 dragging still doesn't work after disabling the selectable layer.
>> Any suggestions for how I might be able to get a draggable layer and
>> separate popup-producing layer working simultaneously on one map?
>> Here are routines I'm using to construct the layers:
>> var map;
>> function init() {
>>     map = new OpenLayers.Map('map');
>>     map.addControl(new OpenLayers.Control.LayerSwitcher());
>>     map.addLayer(
>>        new OpenLayers.Layer.WMS("OpenLayers WMS",
>>             "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} )
>>     map.setCenter(new OpenLayers.Geometry.Point(0, 0), 4);
>>     add_draggable();
>>     add_selectable();
>> function add_draggable() {
>>     var draggable = new OpenLayers.Layer.Vector(
>>             "Draggable",
>>                 styleMap: new OpenLayers.StyleMap({
>>                     externalGraphic:
>>                         "http://openlayers.org/dev/img/marker-gold.png",
>>                     pointRadius: 10
>>     map.addLayer(draggable)
>>     draggable.addFeatures([
>>         new OpenLayers.Feature.Vector(
>>     var dragFeature = new OpenLayers.Control.DragFeature(draggable);
>>     map.addControl(dragFeature);
>>     dragFeature.activate();
>> function add_selectable() {
>>     var selectable = new OpenLayers.Layer.Vector("Selectable");
>>     selectable.addFeatures([
>>              new OpenLayers.Geometry.Point(5, 5)),
>>              new OpenLayers.Geometry.Point(-5, -5)),
>>     map.addLayer(selectable);
>>     var selectControl = new
>>          OpenLayers.Control.SelectFeature(selectable);
>>     map.addControl(selectControl);
>>     selectControl.activate();
>> cheers,
>> Charlie
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Envoyé avec mon mobile
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
View this message in context: http://n2.nabble.com/combining-drag-and-select-layers-on-one-map-drag-not-working-tp2585226p4184443.html
