[OpenLayers-Users] combining drag and select layers on one map
- drag not working
Ivan Grcic
igrcic at gmail.com
Fri Dec 18 03:13:58 EST 2009
selectControl.handlers['feature'].stopDown = false;
selectControl.handlers['feature'].stopUp = false;
is not working, right?
On Fri, Dec 18, 2009 at 1:57 AM, mehmet <m.sirin07 at googlemail.com> wrote:
> hi,
> I intend to do the same and experienced too that this is not possible.
> Is there really no solution to this issue? No one has an idea to solve this
> problem?
> I need to do this, because on layer1 i got some draggable marker and on
> layer2 wfs-features with pop-ups.
> regards
> m.sirin
> Eric Lemoine-2-2 wrote:
>> Hi
>> As you've noticed, since recently, you can have a select feature
>> control work with multiple vector layers. Yet, Andreas or others will
>> correct me if I'm wrong, your use case isn't covered - you cannot have
>> a drag control, working on one layer, and a select control working, on
>> another layer, activated at the same time. Only the layer(s) of the
>> control activated last will be interactive.
>> Eric
>> 2009/4/4, Charlie DeTar <chazen at gmail.com>:
>>> Hi,
>>> I'm trying to construct a map that contains a draggable marker in
>>> addition to features that, when clicked, produce a popup. Reading the
>>> docs and examples, it seemed that the way to do this is to use a vector
>>> layer with a DragFeature control, and an additional vector layer with a
>>> SelectFeature control to handle popups. However, I'm finding that once
>>> the SelectFeature control has been activated, the DragFeature no longer
>>> works -- dragging only pans the map. I'm testing this using Firefox 3.0
>>> under Linux with stable OpenLayers (2.7).
>>> I've been trying to figure out if this has something to do with event
>>> propagation, and have tried setting stopUp and stopDown to false for
>>> both the dragFeature and selectFeature handlers to no effect. Calling
>>> dragFeature.handlers.feature.moveLayerToTop() makes the drag handler
>>> work, but kills the selectFeature, regardless of what order the layers
>>> are added. Though I would like both layers working simultaneously, I
>>> did find that disabling the selectable layer using the LayerSwitcher
>>> made the drag control work again in stable 2.7, but in the latest SVN
>>> R9190 dragging still doesn't work after disabling the selectable layer.
>>> Any suggestions for how I might be able to get a draggable layer and
>>> separate popup-producing layer working simultaneously on one map?
>>> Here are routines I'm using to construct the layers:
>>> var map;
>>> function init() {
>>> map = new OpenLayers.Map('map');
>>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>>> map.addLayer(
>>> new OpenLayers.Layer.WMS("OpenLayers WMS",
>>> "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} )
>>> map.setCenter(new OpenLayers.Geometry.Point(0, 0), 4);
>>> add_draggable();
>>> add_selectable();
>>> function add_draggable() {
>>> var draggable = new OpenLayers.Layer.Vector(
>>> "Draggable",
>>> styleMap: new OpenLayers.StyleMap({
>>> externalGraphic:
>>> "http://openlayers.org/dev/img/marker-gold.png",
>>> pointRadius: 10
>>> map.addLayer(draggable)
>>> draggable.addFeatures([
>>> new OpenLayers.Feature.Vector(
>>> var dragFeature = new OpenLayers.Control.DragFeature(draggable);
>>> map.addControl(dragFeature);
>>> dragFeature.activate();
>>> function add_selectable() {
>>> var selectable = new OpenLayers.Layer.Vector("Selectable");
>>> selectable.addFeatures([
>>> new OpenLayers.Geometry.Point(5, 5)),
>>> new OpenLayers.Geometry.Point(-5, -5)),
>>> map.addLayer(selectable);
>>> var selectControl = new
>>> OpenLayers.Control.SelectFeature(selectable);
>>> map.addControl(selectControl);
>>> selectControl.activate();
>>> cheers,
>>> Charlie
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Envoyé avec mon mobile
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> Users mailing list
> View this message in context: http://n2.nabble.com/combining-drag-and-select-layers-on-one-map-drag-not-working-tp2585226p4184443.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Ivan Grcic
