[OpenLayers-Users] combining drag and select layers on one map - drag not working
mehmet m.sirin07 at googlemail.com
Fri Dec 18 05:26:00 EST 2009
hi,
no it's not working. No effect on anything.
Ivan Grcic-2 wrote:
> Hi,
>     selectControl.handlers['feature'].stopDown = false;
>     selectControl.handlers['feature'].stopUp = false;
> is not working, right?
> On Fri, Dec 18, 2009 at 1:57 AM, mehmet <m.sirin07 at googlemail.com> wrote:
>> hi,
>> I intend to do the same and experienced too that this is not possible.
>> Is there really no solution to this issue? No one has an idea to solve
>> this
>> problem?
>> I need to do this, because on layer1 i got some draggable marker and on
>> layer2 wfs-features with pop-ups.
>> regards
>> m.sirin
>> Eric Lemoine-2-2 wrote:
>>> Hi
>>> As you've noticed, since recently, you can have a select feature
>>> control work with multiple vector layers. Yet, Andreas or others will
>>> correct me if I'm wrong, your use case isn't covered - you cannot have
>>> a drag control, working on one layer, and a select control working, on
>>> another layer, activated at the same time. Only the layer(s) of the
>>> control activated last will be interactive.
>>> Eric
View this message in context: http://n2.nabble.com/combining-drag-and-select-layers-on-one-map-drag-not-working-tp2585226p4185867.html
