[OpenLayers-Users] rendering WFS and vectors based on zoom levels
Arnd Wippermann arnd.wippermann at web.de
Fri Dec 18 15:37:19 EST 2009
minScale and maxScale or minResolution and maxResolution should do the
trick.
        function layerGML_BW(title, url, projection)
            var lyr = new OpenLayers.Layer.Vector(title , {
                minScale : 4000,
                maxScale : 50,
                projection: projection,
                strategies: [new OpenLayers.Strategy.Fixed()],
                protocol: new OpenLayers.Protocol.HTTP({
                    url: url,
                    format: new OpenLayers.Format.GML({
                        extractAttributes: true
            return(lyr);
from http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp
if you zoom into the small recangles, a layer with labels will show up.
Arnd
  _____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Lammie Jonson
Gesendet: Donnerstag, 17. Dezember 2009 22:33
An: users at openlayers.org
Betreff: [OpenLayers-Users] rendering WFS and vectors based on zoom levels
 I figured out how to render WFS from my website using a proxy. The browser
will send a request like this
to the server:
  Parameters: {"url"=>"http://mysite.com?typename=topp%3Astates
<http://mysite.com?typename=topp%3Astates&SERVICE=WFS&VERSION=1.0.0&REQUEST=
GetFeature&SRS=EPSG%3A4326&BBOX=-570.9375,-457.646484375,819.84375,380.47851
5625>
&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=-570.9375
,-457.646484375,819.84375,380.478515625"}
 Suppose I only want the content rendered through WFS to only be visible at
lower zoom levels, is there a way to indicate this in openlayers in the
constructor for the WFS layer ?
 I would like to also be able to do that for any other vector data as well.
I could do this in a variety of ways using session data through a cookie or
by somehow checking the map zoom level whenever the map moves. In the case
of WFS, maybe I could somehow figure out the zoom level from the bounding
box, but if there is a more transparent way to do that I would like to do it
that way or whatever is the preferred cleaner approach, etc.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091218/2893539c/attachment.html
