[OpenLayers-Users] Problems embedding OpenLayers in a Blog
jamesmikedupont at googlemail.com jamesmikedupont at googlemail.com
Wed Dec 23 05:17:28 EST 2009
Hi there,
I have attempted to embed openlayers in a blog post,
and am failing! Any help would be appreciated.
using osm data hosted OSM data on archive.org
http://osmopenlayers.blogspot.com/2009/12/test-embed.html
here is get a octet bytestream because archive org does not say the
right filetype.
http://ia341335.us.archive.org/2/items/ZCTA_NJ/zip_07003.poly.osm this
returns a 206 partial content and fails.
in a pastebin file that is delivered as text:
http://osmopenlayers.blogspot.com/2009/12/hosting-on-pastebin.html
Date	Wed, 23 Dec 2009 10:15:43 GMT
Server	Apache/1.3.33 (Debian GNU/Linux) mod_python/2.7.10 Python/2.3.4
PHP/4.3.10-22 mod_perl/1.29
X-Powered-By	PHP/4.3.10-22
Content-Disposition	attachment; filename="f28514ba0.txt"
Keep-Alive	timeout=15, max=100
Connection	Keep-Alive
Transfer-Encoding	chunked
Content-Type	text/plain; charset=iso-8859-1
So the problem might be the attachment...
and that data from osm directly again on pastebin,
http://osmopenlayers.blogspot.com/2009/12/osm-data-from-xml-output-on-pastebin.html
data is here :http://pastebin.com/pastebin.php?dl=f290d5ea6 it returns a 200 ok.
It returns an :	text/plain; charset=iso-8859-1 but does not render.
But there is still nothing there
from osm directly
http://osmopenlayers.blogspot.com/2009/12/get-osm-data-directly.html
firebug says :no element found
And my last try was to put the code from osm on the page directly,
also not rendering but the xml is loading.
http://osmopenlayers.blogspot.com/2009/12/test-of-osm-server.html
but nothing is working
would appreciate any tips and help
thanks
mike
