[OpenLayers-Users] Problems embedding OpenLayers in a Blog
jamesmikedupont at googlemail.com jamesmikedupont at googlemail.com
Wed Dec 23 09:38:32 EST 2009
Thanks for your advice. That is interesting.
I never did anything like this, and I feed pretty stupid right now!
But it will be possible to host the webpages on archive.org as well
and work without the blog itself. It just would be nice to separate
the display and the data storage. That effectively reduces the usage
of openlayers to people who have control of domains, right? It will
not be possible to people to just create maps with any data they want
without a server to proxy the data.
Now, this example, it displays an openstreetmap map
http://osmopenlayers.blogspot.com/2009/12/test-of-osm-server.html
but the fetch to :
http://www.openstreetmap.org/api/0.6/way/24315294/full
that fails, or never returns.
But the same one to use open layer to load the data from osm fails :
http://osmopenlayers.blogspot.com/2009/12/get-osm-data-directly.html
It calles get on this url http://www.openstreetmap.org/api/0.6/way/24315294
in the request	XMLHttpRequest.js (line 200)
the other thing is that I dont get any error message about security problems
I found this document here:
http://docs.openlayers.org/library/request.html
So, realistically it is not possible to host open layers on a blog?
mike
On Wed, Dec 23, 2009 at 1:37 PM, Marc Jansen <jansen at terrestris.de> wrote:
> Hi Mike,
> I am pretty sure that you aren't allowed to acces datasources via XHR/AJAX
> from other servers than the one the original page is served from.
> see: http://en.wikipedia.org/wiki/Same_origin_policy
> Just a quick guess, though.
> regards,
> Marc
> jamesmikedupont at googlemail.com wrote:
>> Hi there,
>> I have attempted to embed openlayers in a blog post,
>> and am failing! Any help would be appreciated.
>> using osm data hosted OSM data on archive.org
>> http://osmopenlayers.blogspot.com/2009/12/test-embed.html
>> here is get a octet bytestream because archive org does not say the
>> right filetype.
>> http://ia341335.us.archive.org/2/items/ZCTA_NJ/zip_07003.poly.osm this
>> returns a 206 partial content and fails.
>> in a pastebin file that is delivered as text:
>> http://osmopenlayers.blogspot.com/2009/12/hosting-on-pastebin.html
>> Date    Wed, 23 Dec 2009 10:15:43 GMT
>> Server  Apache/1.3.33 (Debian GNU/Linux) mod_python/2.7.10 Python/2.3.4
>> PHP/4.3.10-22 mod_perl/1.29
>> X-Powered-By    PHP/4.3.10-22
>> Content-Disposition     attachment; filename="f28514ba0.txt"
>> Keep-Alive      timeout=15, max=100
>> Connection      Keep-Alive
>> Transfer-Encoding       chunked
>> Content-Type    text/plain; charset=iso-8859-1
>> So the problem might be the attachment...
>> and that data from osm directly again on pastebin,
>> http://osmopenlayers.blogspot.com/2009/12/osm-data-from-xml-output-on-pastebin.html
>> data is here :http://pastebin.com/pastebin.php?dl=f290d5ea6 it returns a
>> 200 ok.
>> It returns an : text/plain; charset=iso-8859-1 but does not render.
>> But there is still nothing there
>> from osm directly
>> firebug says :no element found
>> And my last try was to put the code from osm on the page directly,
>> also not rendering but the xml is loading.
>> but nothing is working
>> would appreciate any tips and help
>> thanks
>> mike
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>  Dipl.-Geogr. Marc Jansen
>  - Anwendungsentwickler -
>  terrestris GmbH & Co. KG
>  Irmintrudisstraße 17
>  53111 Bonn
>  Tel:    ++49 (0)228 / 96 28 99 -53
>  Fax:    ++49 (0)228 / 96 28 99 -57
>  Email:  jansen at terrestris.de
>  Web:    http://www.terrestris.de
>  Amtsgericht Bonn, HRA 6835
>  Komplementärin:  terrestris Verwaltungsgesellschaft mbH
>  vertreten durch: Hinrich Paulsen, Till Adams
