[OpenLayers-Users] Problem in openlayers when migrating from Mapserver 5.0 to 5.2
afrozk afrozk at gmail.com
Thu Dec 24 02:53:57 EST 2009
I have a WMS worldmap layer which was working fine in mapserver 5.0 with
openlayers 2.8
Now when I migrated to mapserver 5.2, the worldmap layer in repeating as
tiles.
Below is my code, Only copied the relevant part.
//Variables
var country_options 	= {displayInLayerSwitcher: true,opacity: 0.7};
var extent 		= new OpenLayers.Bounds(-57,-55,175,80);
var map_options		= {'maxExtent': extent,numZoomLevels:6,restrictedExtent:
extent}
  // Inside the init function.
map             = new OpenLayers.Map( 'map', map_options);
countrylayer  = new OpenLayers.Layer.WMS( "Country Outline",
                    "http://" + server + "/cgi-bin/mapserv.exe?",
		{map:'../htdocs/ms/stats.map',mode:'map',layers: 'cntry98', format:
"image/png"},
			country_options);
// Map File
MAP
	IMAGETYPE      PNG24
	EXTENT 		-45 -55 175 75
	SIZE           980 700
	SHAPEPATH      "./data"
	IMAGECOLOR     217 236 255 #255 230 255
	FONTSET        "./fonts/fonts.list"
	SYMBOLSET      "./fonts/vectors.sym"
	PROJECTION
	"init=epsg:4326"  #2163 4326 26915
	END
	WEB
	IMAGEPATH "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
	IMAGEURL  "/ms/tmp/"
	LOG "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
	END
	# Start of LAYER DEFINITIONS ---------------------------------------------
	LAYER # Country polygon layer begins here
		NAME         cntry98
		DATA         cntry98
		STATUS       OFF
		TYPE         POLYGON
		PROJECTION
		  "init=epsg:4326"  # 4326 26915
		END
		TRANSPARENCY 80
		CLASSITEM    "CNTRY_NAME"
		CLASS
		  NAME       "COUNTRY"
		  STYLE
			   COLOR         255 255 232
			   OUTLINECOLOR  0 0 0
		  END
		END
	END # Country polygon layer ends here
END
The map works fine if I change OpenLayers.Layer.WMS  to
OpenLayers.Layer.MapServer, but I cant use that option at it would affect
the code in other places.
Any help would be highly appreciated.
Thanks in advance
View this message in context: http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212330.html
