[OpenLayers-Users] Problem in openlayers when migrating from Mapserver 5.0 to 5.2
bartvde at osgis.nl bartvde at osgis.nl
Thu Dec 24 02:59:34 EST 2009
What do you mean with repeating as tiles? Can you show an example, a
screendump of what is wrong?
Also, your WMS layer should not get the parameters mode and layers, remove
them from your Layer.WMS definition.
Best regards,
Bart
> I have a WMS worldmap layer which was working fine in mapserver 5.0 with
> openlayers 2.8
> Now when I migrated to mapserver 5.2, the worldmap layer in repeating as
> tiles.
> Below is my code, Only copied the relevant part.
> //Variables
> var country_options 	= {displayInLayerSwitcher: true,opacity: 0.7};
> var extent 		= new OpenLayers.Bounds(-57,-55,175,80);
> var map_options		= {'maxExtent': extent,numZoomLevels:6,restrictedExtent:
> extent}
>   // Inside the init function.
> map             = new OpenLayers.Map( 'map', map_options);
> countrylayer  = new OpenLayers.Layer.WMS( "Country Outline",
>                     "http://" + server + "/cgi-bin/mapserv.exe?",
> 		{map:'../htdocs/ms/stats.map',mode:'map',layers: 'cntry98', format:
> "image/png"},
> 			country_options);
> // Map File
> MAP
> 	IMAGETYPE      PNG24
> 	EXTENT 		-45 -55 175 75
> 	SIZE           980 700
> 	SHAPEPATH      "./data"
> 	IMAGECOLOR     217 236 255 #255 230 255
> 	FONTSET        "./fonts/fonts.list"
> 	SYMBOLSET      "./fonts/vectors.sym"
> 	PROJECTION
> 	"init=epsg:4326"  #2163 4326 26915
> 	END
> 	WEB
> 	IMAGEPATH "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
> 	IMAGEURL  "/ms/tmp/"
> 	LOG "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
> 	END
> 	# Start of LAYER DEFINITIONS
> 	LAYER # Country polygon layer begins here
> 		NAME         cntry98
> 		DATA         cntry98
> 		STATUS       OFF
> 		TYPE         POLYGON
> 		PROJECTION
> 		  "init=epsg:4326"  # 4326 26915
> 		END
> 		TRANSPARENCY 80
> 		CLASSITEM    "CNTRY_NAME"
> 		CLASS
> 		  NAME       "COUNTRY"
> 		  STYLE
> 			   COLOR         255 255 232
> 			   OUTLINECOLOR  0 0 0
> 		  END
> 		END
> 	END # Country polygon layer ends here
> END
> The map works fine if I change OpenLayers.Layer.WMS  to
> OpenLayers.Layer.MapServer, but I cant use that option at it would affect
> the code in other places.
> Any help would be highly appreciated.
> Thanks in advance
> http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212330.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
