[OpenLayers-Users] Problem in openlayers when migrating from Mapserver 5.0 to 5.2
afrozk afrozk at gmail.com
Thu Dec 24 03:14:54 EST 2009
Thankyou Bart for your quick reply.
 Please find attached the screenshot.
Thanks
Afroz
Bart van den Eijnden wrote:
> What do you mean with repeating as tiles? Can you show an example, a
> screendump of what is wrong?
> Also, your WMS layer should not get the parameters mode and layers, remove
> them from your Layer.WMS definition.
> Best regards,
> Bart
>> I have a WMS worldmap layer which was working fine in mapserver 5.0 with
>> openlayers 2.8
>> Now when I migrated to mapserver 5.2, the worldmap layer in repeating as
>> tiles.
>> Below is my code, Only copied the relevant part.
>> //Variables
>> var country_options 	= {displayInLayerSwitcher: true,opacity: 0.7};
>> var extent 		= new OpenLayers.Bounds(-57,-55,175,80);
>> var map_options		= {'maxExtent': extent,numZoomLevels:6,restrictedExtent:
>> extent}
>>   // Inside the init function.
>> map             = new OpenLayers.Map( 'map', map_options);
>> countrylayer  = new OpenLayers.Layer.WMS( "Country Outline",
>>                     "http://" + server + "/cgi-bin/mapserv.exe?",
>> 		{map:'../htdocs/ms/stats.map',mode:'map',layers: 'cntry98', format:
>> "image/png"},
>> 			country_options);
>> // Map File
>> MAP
>> 	IMAGETYPE      PNG24
>> 	EXTENT 		-45 -55 175 75
>> 	SIZE           980 700
>> 	SHAPEPATH      "./data"
>> 	IMAGECOLOR     217 236 255 #255 230 255
>> 	FONTSET        "./fonts/fonts.list"
>> 	SYMBOLSET      "./fonts/vectors.sym"
>> 	PROJECTION
>> 	"init=epsg:4326"  #2163 4326 26915
>> 	END
>> 	WEB
>> 	IMAGEPATH "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
>> 	IMAGEURL  "/ms/tmp/"
>> 	LOG "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
>> 	END
>> 	# Start of LAYER DEFINITIONS
>> 	LAYER # Country polygon layer begins here
>> 		NAME         cntry98
>> 		DATA         cntry98
>> 		STATUS       OFF
>> 		TYPE         POLYGON
>> 		PROJECTION
>> 		  "init=epsg:4326"  # 4326 26915
>> 		END
>> 		TRANSPARENCY 80
>> 		CLASSITEM    "CNTRY_NAME"
>> 		CLASS
>> 		  NAME       "COUNTRY"
>> 		  STYLE
>> 			   COLOR         255 255 232
>> 			   OUTLINECOLOR  0 0 0
>> 		  END
>> 		END
>> 	END # Country polygon layer ends here
>> END
>> The map works fine if I change OpenLayers.Layer.WMS  to
>> OpenLayers.Layer.MapServer, but I cant use that option at it would affect
>> the code in other places.
>> Any help would be highly appreciated.
>> Thanks in advance
>> View this message in context:
>> http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212330.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
http://n2.nabble.com/file/n4212380/ss.jpg
View this message in context: http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212380.html
