[OpenLayers-Users] Problem in openlayers when migrating from Mapserver 5.0 to 5.2
bartvde at osgis.nl bartvde at osgis.nl
Thu Dec 24 03:20:22 EST 2009
did you try and leave out the parameter mode like I said in my first e-mail?
It looks like every tile retrieves a full map, because you use mode=map in
your parameter list. Remove it, so use:
countrylayer  = new OpenLayers.Layer.WMS( "Country Outline",
  "http://" + server + "/cgi-bin/mapserv.exe?",
  {map:'../htdocs/ms/stats.map', layers: 'cntry98', format: "image/png"},
  country_options);
Best regards,
Bart
> Thankyou Bart for your quick reply.
>  Please find attached the screenshot.
> Thanks
> Afroz
> Bart van den Eijnden wrote:
>> What do you mean with repeating as tiles? Can you show an example, a
>> screendump of what is wrong?
>> Also, your WMS layer should not get the parameters mode and layers,
>> remove
>> them from your Layer.WMS definition.
>> Best regards,
>> Bart
>>> I have a WMS worldmap layer which was working fine in mapserver 5.0
>>> with
>>> openlayers 2.8
>>> Now when I migrated to mapserver 5.2, the worldmap layer in repeating
>>> as
>>> tiles.
>>> Below is my code, Only copied the relevant part.
>>> //Variables
>>> var country_options 	= {displayInLayerSwitcher: true,opacity: 0.7};
>>> var extent 		= new OpenLayers.Bounds(-57,-55,175,80);
>>> var map_options		= {'maxExtent':
>>> extent,numZoomLevels:6,restrictedExtent:
>>> extent}
>>>   // Inside the init function.
>>> map             = new OpenLayers.Map( 'map', map_options);
>>> 		{map:'../htdocs/ms/stats.map',mode:'map',layers: 'cntry98', format:
>>> "image/png"},
>>> 			country_options);
>>> // Map File
>>> MAP
>>> 	IMAGETYPE      PNG24
>>> 	EXTENT 		-45 -55 175 75
>>> 	SIZE           980 700
>>> 	SHAPEPATH      "./data"
>>> 	IMAGECOLOR     217 236 255 #255 230 255
>>> 	FONTSET        "./fonts/fonts.list"
>>> 	SYMBOLSET      "./fonts/vectors.sym"
>>> 	PROJECTION
>>> 	"init=epsg:4326"  #2163 4326 26915
>>> 	END
>>> 	WEB
>>> 	IMAGEPATH "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
>>> 	IMAGEURL  "/ms/tmp/"
>>> 	LOG "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
>>> 	END
>>> 	# Start of LAYER DEFINITIONS
>>> 	LAYER # Country polygon layer begins here
>>> 		NAME         cntry98
>>> 		DATA         cntry98
>>> 		STATUS       OFF
>>> 		TYPE         POLYGON
>>> 		PROJECTION
>>> 		  "init=epsg:4326"  # 4326 26915
>>> 		END
>>> 		TRANSPARENCY 80
>>> 		CLASSITEM    "CNTRY_NAME"
>>> 		CLASS
>>> 		  NAME       "COUNTRY"
>>> 		  STYLE
>>> 			   COLOR         255 255 232
>>> 			   OUTLINECOLOR  0 0 0
>>> 		  END
>>> 		END
>>> 	END # Country polygon layer ends here
>>> END
>>> The map works fine if I change OpenLayers.Layer.WMS  to
>>> OpenLayers.Layer.MapServer, but I cant use that option at it would
>>> affect
>>> the code in other places.
>>> Any help would be highly appreciated.
>>> Thanks in advance
>>> View this message in context:
>>> http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212330.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> http://n2.nabble.com/file/n4212380/ss.jpg
> http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212380.html
> Users mailing list
