[OpenLayers-Users] Problem in openlayers when migrating from Mapserver 5.0 to 5.2
afrozk afrozk at gmail.com
Thu Dec 24 04:06:40 EST 2009
    It works fine now when I removed the mode=map option.
I did not remove the  layers option. Please tell me where else do I specify
the
layers option if it is removed from there, just to know it .
Thanks a lot
Afroz
Bart van den Eijnden wrote:
> Hi,
> did you try and leave out the parameter mode like I said in my first
> e-mail?
> It looks like every tile retrieves a full map, because you use mode=map in
> your parameter list. Remove it, so use:
> countrylayer  = new OpenLayers.Layer.WMS( "Country Outline",
>   "http://" + server + "/cgi-bin/mapserv.exe?",
>   {map:'../htdocs/ms/stats.map', layers: 'cntry98', format: "image/png"},
>   country_options);
> Best regards,
> Bart
>> Thankyou Bart for your quick reply.
>>  Please find attached the screenshot.
>> Thanks
>> Afroz
>>> What do you mean with repeating as tiles? Can you show an example, a
>>> screendump of what is wrong?
>>> Also, your WMS layer should not get the parameters mode and layers,
>>> remove
>>> them from your Layer.WMS definition.
>>> Best regards,
>>> Bart
>>>> I have a WMS worldmap layer which was working fine in mapserver 5.0
>>>> with
>>>> openlayers 2.8
>>>> Now when I migrated to mapserver 5.2, the worldmap layer in repeating
>>>> as
>>>> tiles.
>>>> Below is my code, Only copied the relevant part.
>>>> //Variables
>>>> var country_options 	= {displayInLayerSwitcher: true,opacity: 0.7};
>>>> var extent 		= new OpenLayers.Bounds(-57,-55,175,80);
>>>> var map_options		= {'maxExtent':
>>>> extent,numZoomLevels:6,restrictedExtent:
>>>> extent}
>>>>   // Inside the init function.
>>>> map             = new OpenLayers.Map( 'map', map_options);
>>>> 		{map:'../htdocs/ms/stats.map',mode:'map',layers: 'cntry98', format:
>>>> "image/png"},
>>>> 			country_options);
>>>> // Map File
>>>> MAP
>>>> 	IMAGETYPE      PNG24
>>>> 	EXTENT 		-45 -55 175 75
>>>> 	SIZE           980 700
>>>> 	SHAPEPATH      "./data"
>>>> 	IMAGECOLOR     217 236 255 #255 230 255
>>>> 	FONTSET        "./fonts/fonts.list"
>>>> 	SYMBOLSET      "./fonts/vectors.sym"
>>>> 	PROJECTION
>>>> 	"init=epsg:4326"  #2163 4326 26915
>>>> 	END
>>>> 	WEB
>>>> 	IMAGEPATH "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
>>>> 	IMAGEURL  "/ms/tmp/"
>>>> 	LOG "C:/Programs/ms4w/Apache/htdocs/ms/tmp/"
>>>> 	END
>>>> 	# Start of LAYER DEFINITIONS
>>>> 	LAYER # Country polygon layer begins here
>>>> 		NAME         cntry98
>>>> 		DATA         cntry98
>>>> 		STATUS       OFF
>>>> 		TYPE         POLYGON
>>>> 		PROJECTION
>>>> 		  "init=epsg:4326"  # 4326 26915
>>>> 		END
>>>> 		TRANSPARENCY 80
>>>> 		CLASSITEM    "CNTRY_NAME"
>>>> 		CLASS
>>>> 		  NAME       "COUNTRY"
>>>> 		  STYLE
>>>> 			   COLOR         255 255 232
>>>> 			   OUTLINECOLOR  0 0 0
>>>> 		  END
>>>> 		END
>>>> 	END # Country polygon layer ends here
>>>> END
>>>> The map works fine if I change OpenLayers.Layer.WMS  to
>>>> OpenLayers.Layer.MapServer, but I cant use that option at it would
>>>> affect
>>>> the code in other places.
>>>> Any help would be highly appreciated.
>>>> Thanks in advance
>>>> View this message in context:
>>>> http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212330.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> http://n2.nabble.com/file/n4212380/ss.jpg
>> http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212380.html
>> Users mailing list
> Users mailing list
View this message in context: http://n2.nabble.com/Problem-in-openlayers-when-migrating-from-Mapserver-5-0-to-5-2-tp4212330p4212502.html
