[OpenLayers-Users] Duplicated Google Maps copyright controls
Alexandre Saunier alexandre.saunier at camptocamp.com
Sat Dec 26 17:15:55 EST 2009
Hey Eric,
thanks for replying!
Yes I use OL trunk and so does the example that illustrates the problem:
http://openlayers.org/dev/examples/spherical-mercator.html
I now realize that my previous mail subject was confusing. The Google
Maps "attribution" control is not duplicated because of two layers
displayed at the same time. The problem is rather that the GM
"attribution" link/text of the previously selected base layer is still
displayed (in some cases) even when another base layer has been
selected in the meantime.
In the case study provided in my first message, you can see that two
GM "attributions" are stacked when switching from "Google streets" to
"Google Satellite" or "Google Hybrid" for the first time. It also
occurs when switching to some other base layer like VE or OSM. In fact
it seems that the first GM base layer attribution control is not
cleared (deactivated?) when the base layer changes.
alex
2009/12/26 Eric Lemoine <eric.lemoine at camptocamp.com>:
> On Friday, December 25, 2009, Alexandre Saunier
> <alexandre.saunier at camptocamp.com> wrote:
>> Hello all,
>> I don't know if the topic has already been discussed but I notice a
>> strange behaviour with some OL maps using Google layers: for instance
>> when viewing http://openlayers.org/dev/examples/spherical-mercator.html
>> with Firefox and switching the base layer to "Google satellite" (or
>> hybrid), one may notice that the Google copyright in the bottom left
>> corner is duplicated  (pan the map a little bit to have a non-white
>> background). Then it's ok when switching to an other baselayer.
>> I observe the same issue in one of my OL applications. Is there a way
>> to avoid it?
>> Thank you for your help (and happy holidays),
> Hi Alex. Do you OL trunk in your app? Patches addressing duplicate
> attributions were committed recently, see #2266 and #2300.
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
