[OpenLayers-Users] combining handlers, or hover + select
Jesse V Griffis jvgriffis at gmail.com
Mon Feb 2 22:03:45 EST 2009
Greetings,
I can successfully use the hover examples to create a "Hover" Control
that uses the Hover handler to pop up info when you pause in one place
long enough.  I can successfully use the SelectFeature Control to
click and display info about Vectors.
What I can't figure out is how to combine them, and make a pause on
the map select the feature under the mouse.  It's frustrating to get
so close and yet be so far.
Does anyone have an example of this?
Thanks,
Jesse
