[OpenLayers-Users] combining handlers, or hover + select
Eric Lemoine eric.c2c at gmail.com
Tue Feb 3 01:03:41 EST 2009
Hi
It is hard to help you without seeing actual code. Feel free to come
back to the list with your code.
Cheers,
Eric
2009/2/3, Jesse V Griffis <jvgriffis at gmail.com>:
> Greetings,
> I can successfully use the hover examples to create a "Hover" Control
> that uses the Hover handler to pop up info when you pause in one place
> long enough.  I can successfully use the SelectFeature Control to
> click and display info about Vectors.
> What I can't figure out is how to combine them, and make a pause on
> the map select the feature under the mouse.  It's frustrating to get
> so close and yet be so far.
> Does anyone have an example of this?
> Thanks,
> Jesse
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
