[OpenLayers-Users] FW: GetFeatureInfo not working
N M nm3456 at gmail.com
Tue Feb 3 13:53:36 EST 2009
Now the proxy script is working OK (http://84.205.237.73/script/proxy.py),
thanks to:
http://python.markrowsoft.com/iiswse.asp (very detailed info about python
setup in Win Server 2003 with IIS6)
But we still don't get any answer to our GetFeatureInfo request.
Specifically, we get the following message from the browser:
Some unexpected error occurred. Error text was: <urlopen error [Errno 10060]
A connection attempt failed because the connected party did not
properly respond after a period of time,
or established connection failed because connected host has failed to respond>
For example use this url:
http://84.205.237.73/script/proxy.py?url=http%3A%2F%2F84.205.237.73%3A443%2Fgeoserver%2Fwms%3FREQUEST%3DGetFeatureInfo%26EXCEPTIONS%3Dapplication%252Fvnd.ogc.se_xml%26BBOX%3D2767167.493482%252C4505675.646451%252C2822912.470114%252C4540167.850742%26X%3D372%26Y%3D230%26INFO_FORMAT%3Dtext%252Fhtml%26QUERY_LAYERS%3DTinos%253Adimoi%26FEATURE_COUNT%3D50%26Layers%3DTinos%253Adimoi%26Styles%3D%26Srs%3DEPSG%253A900913%26WIDTH%3D800%26HEIGHT%3D495%26format%3Dimage%252Fpng
For our demo map go to: http://84.205.237.73/default/demomap.aspx
Any other suggestions???
Thanks
Nikos
2009/1/26 nm3456 <nm3456 at gmail.com>
> -----Original Message-----
> From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
> Sent: Monday, January 26, 2009 11:29 PM
> To: nm3456 at gmail.com
> Cc: users at openlayers.org
> Subject: AW: [OpenLayers-Users] GetFeatureInfo not working
> Hi,
> The proxy script is not availible.
> This page cannot be found http://84.205.237.73/default/charta/proxy.py.
> Arnd Wippermann
> ________________________________
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von nm3456 at gmail.com
> Gesendet: Montag, 26. Januar 2009 21:48
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] GetFeatureInfo not working
> Hi everyone,
> Being newbies with Geoserver-Openlayers, we set up an application, on a
> machine with Windows Server 2003-IIS.
> Everything works fine apart from the GetFeatureInfo calls.
> From firebug, we located the following request, when we click on the map,
> which works fine, when we use it at the browser's address bar:
> http://84.205.237.73:443/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=app
> lication%2Fvnd.ogc.se_xml&BBOX=2767167.493482%2C4505675.646451%2C2822912.470
> 114%2C4540167.850742&X=469&Y=327&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=Tinos%
> 3Adimoi&FEATURE_COUNT=50&Layers=Tinos%3Adimoi&Styles=&Srs=EPSG%3A900913&WIDT
> H=800&HEIGHT=495&format=image%2Fpng
> From the above we concluded that there is a browser security problem.
> So far, we followed:
> 1)
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
> 2)
> http://n2.nabble.com/Solution-to-proxy-for-WFS-request-on-IIS-td1830924.html
> #a20353666
> 3)       http://openlayers.org/dev/examples/getfeatureinfo.html
> 4)
> http://n2.nabble.com/GetFeatureInfo-requests-never-get-answers-td1824945.htm
> l#a11586620
> But now, instead of getting an endless "Loading... please wait...",
> we get an "HTTP Error 404 - File or directory not found.", when we click on
> the map.
> I apologize for the Greek language used, but you should be able to browse
> the code :))
> I hope that someone has a suggestion.
>  Nikos
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090203/d56728d5/attachment.html
