[OpenLayers-Users] Feature selection
Dave Potts dave.potts at pinan.co.uk
Tue Feb 3 20:06:58 EST 2009
Christopher Schmidt wrote:
> On Wed, Feb 04, 2009 at 01:00:10AM +0000, Dave Potts wrote:
>> Is it possible to have to vectore features active at the same time and
>> be able to select on both at the same time?
>> I have a map loaded with a map base layer and two vector feature layers.
>> If I install a different callback function on both layers only the last
>> declared one seem to work? ie its only possible to select from one layer
> "As of OpenLayers 2.7, there is no support for selecting features from
> more than a single vector layer at a time. The layer which is currently
> being used for selection is the last one on which the .activate() method
> of the attached select feature control was called." --
> http://docs.openlayers.org/library/overlays
> Regards,
I take back what I said about the documentation!
I only found the javadoc style docuemntation that tells you about the
parmeters, I did'nt find this rather useful page.
Is there any chance of link the two documentation sets?
Dave.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090204/8359c2e2/dave_potts.vcf
