[OpenLayers-Users] How can I show a picture a popup (URL for
the pic should be read automatically from the attributes)
Ivan Grcic
igrcic at gmail.com
Wed Feb 4 08:39:06 EST 2009
im sorry i also dont know so much about Format.XML methods, i mostly
use Format.GML or JSON
but this should help:
http://openlayers.org/dev/examples/xml.html
http://dev.openlayers.org/docs/files/OpenLayers/Format/XML-js.html
Cheers,
On Wed, Feb 4, 2009 at 1:24 PM, Max Stephan <x.zam at gmx.net> wrote:
> Hey Ivan,
> Yes, I checked out this your link. But I don´t have success in transferring
> it to my own document. Here is what I got yet:
> => I perform a GetFeatureInfo-Request on
> "http://localhost:8080/geoserver/wms" with INFO_FORMAT:
> 'application/vnd.ogc.gml'.
> => this is done via
> OpenLayers.loadURL("http://localhost:8080/geoserver/wms", params, this,
> setHTML, setHTML);
> => my setHTML-function now looks like that:
> function setHTML(response){
> var g = new OpenLayers.Format.XML();
> var features = g.read(response.responseText);
> var url = g.getAttributeNS(features.documentElement,
> 'http://www.w3.org/2001/XMLSchema-instance', 'schemaLocation');
> document.getElementById('nodelist').innerHTML=response.responseText;
> document.getElementById('urlOutput').innerHTML=url;}
> In this case it puts out the schemalocation in the urlOutput. But that´s not
> what I want to achieve. So the question is, how can i get other elements out
> of the XML like the ID for example.
> For that I have to competely understand what all those methods do which is
> not the case yet ;-). For example the read-method: does it read the content
> of an XML-File node by node? Or the getAttributeNS-method: What does
> features.documentElement (= the node) mean and why am I not able to refer to
> another name than 'schemalocation' (when I try url, which is an attribute in
> my layer it returns no result).
> thanks for your help
> Max Stephan
> Ivan Grcic-2 wrote:
>> Hi, did you check out http://openlayers.org/dev/examples/GMLParser.html
>> Function load takes ur xml data (which can be getFeatureInfo), and
>> gives it to parseData function, which parses all the features and
>> their attributes...its all you need ;)
>> And i suggest to make it in JSON format, its much lighter
>> function load() {
>> OpenLayers.loadURL("gml/owls.xml", "", null, parseData);
>> function parseData(req) {
>> g = new OpenLayers.Format.GML();
>> html = ""
>> features = g.read(req.responseText);
>> for(var feat in features) {
>> html += "Feature: Geometry: "+ features[feat].geometry+",";
>> html += "<ul>";
>> for (var j in features[feat].attributes) {
>> html += "<li>"+j+":"+features[feat].attributes[j]+"</li>";
>> html += "</ul>"
>> document.getElementById('output').innerHTML = html;
>> Cheers
>> On Tue, Feb 3, 2009 at 9:09 PM, Max Stephan <x.zam at gmx.net> wrote:
>>> Ok, that sounds like an idea.
>>> I´ve been reading a bit more about JavaScript-development in general. So
>>> I
>>> developed the following change in the setHTML-function that allows me to
>>> show a picture when the function is executed.
>>> var img = document.createElement("img");
>>> img.setAttribute("src", "qu18_2.jpg");
>>> document.getElementById('pic-container').replaceChild(img,document.getElementById('pic-container').lastChild);}
>>> This works fine for a predefined pic. But how can I get the specific
>>> attribute that contains the URL out of the getFeatureRequest-response. So
>>> what I´m searching for is something like "response.getContent[5]"
>>> (fictional
>>> code ;-)).
>>> So, as you see, by now it´s a bit abstract to me what I exactly get back
>>> from this getFeatureRequest and how I can get further informations out of
>>> it...
>>> Thank you for your help Ivan and Till and thanks to everyone else in
>>> advance
>>> Max Stephan
>>> Till Adams wrote:
>>>> Max,
>>>> in general you need to define your output format which comes back from
>>>> Geoserver as text or Xml or whatever - then you may parse the backcoming
>>>> stuff and put the URL in an html image tag - basically you can see what
>>>> to
>>>> do regarding the OL featureinfo example::
>>>> you must do alter it at the place when you receive the result from your
>>>> WMS
>>>> back and before you put it this in the result-div in your client -
>>>> you'll
>>>> have to parse it and rewrite it to html, alternatively you may define a
>>>> template for your WMS which gives the results back in Html, so you can
>>>> do
>>>> sth like:
>>>> <html>
>>>> [URL]
>>>> Where [URL] will be filled by your WMS server - this is mainly the
>>>> proceeding I know from UMN mapserver.
>>>> Just some ideas - regards, Till
>>>> "Max Stephan" <x.zam at gmx.net> schrieb:
>>>>> Hey everybody!
>>>>> I got a shapefile here which I added to my geoserver. I have integrated
>>>>> it
>>>>> as a layer in an openlayers map container. In the attributes of the
>>>>> layer/shapefile is a field which contains an URL to a pic of each
>>>>> feature
>>>>> (in this case the features are points). Now I want this picture to be
>>>>> displayed in a popup (like it can be done in a marker layer). But I
>>>>> want
>>>> to
>>>>> have the URL automatically read from the attributes of the feature I´m
>>>>> clicking on. It would be great to see some of the other attributes read
>>>> from
>>>>> the feature as well. The problem is I don´t know that much about the
>>>>> OpenLayers-API. I only know how to write a GetFeatureRequest but this
>>>> would
>>>>> show me only the attribute table. If it´s too difficult to show a
>>>>> picture
>>>>> which´s URL is in the attributes it would be even enough if the URL in
>>>>> the
>>>>> attribute table (the one I get from the GetFeatureRequest) would be
>>>>> clickable.
>>>>> Greets and thanks for your help in advance Max Stephan
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>>> View this message in context:
>>> http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2265382.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Ivan Grcic
>> Users mailing list
> View this message in context: http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2268463.html
> Users mailing list
