[OpenLayers-Users] How can I show a picture a popup (URL for the pic should be read automatically from the attributes)
Max Stephan x.zam at gmx.net
Wed Feb 4 13:41:39 EST 2009
Hey,
no problem. But if you´re using Format.GML and more familiar with this:
Isn´t it also possible to realize my document with that? I don´t have to use
XML but that´s the only method I was able to get a logical output of. As I
said I´ve been looking through the GML-Parser-Example but I don´t understand
a few things. I´m gonna try to explain my problems on the example:
function parseData(req) {
=> okay, the function which receives one parameter, in my case this should
be the response from the getFeatureRequest I guess
          g =  new OpenLayers.Format.GML();
          html = ""
          features = g.read(req.responseText);
=> this changes the response into machine-readable text, I guess, using the
GML-object "g"
for(var feat in features) {
            html += "Feature: Geometry: "+ features[feat].geometry+",";
                html += "<ul>";
            for (var j in features[feat].attributes) {
                html += "<li>"+j+":"+features[feat].attributes[j]+"</li>";
                html += "</ul>"
=> okay, this seems to be a loop that gets out all features of the
GML-document. feature[feat] looks like an array, but I don´t understand what
brings this loop to terminate (I come from Java and in for-loops there´s in
most cases something like "counter ++;".
Now if I want to get access to my own features, how could I do that? I tried
features[0].url (where url is an attribute of my features) but I don´t get a
result when I´m trying an output via innerHTML.
In my case I also don´t see a reason for a loop because I only want the
attribute of one feature.
          document.getElementById('output').innerHTML = html;
=> OK, this is clear again, it´s simply changing the content of the <div
id="output"> to the var html which  was defined in the loops before.
I hope I didn´t confuse too much :thinking: and also hope you can help me.
thx in advance
Max Stephan
Ivan Grcic-2 wrote:
> Hi,
> im sorry i also dont know so much about Format.XML methods, i mostly
> use Format.GML or JSON
> but this should help:
> http://openlayers.org/dev/examples/xml.html
> http://dev.openlayers.org/docs/files/OpenLayers/Format/XML-js.html
> Cheers,
> On Wed, Feb 4, 2009 at 1:24 PM, Max Stephan <x.zam at gmx.net> wrote:
>> Hey Ivan,
>> Yes, I checked out this your link. But I don´t have success in
>> transferring
>> it to my own document. Here is what I got yet:
>> => I perform a GetFeatureInfo-Request on
>> "http://localhost:8080/geoserver/wms" with INFO_FORMAT:
>> 'application/vnd.ogc.gml'.
>> => this is done via
>> OpenLayers.loadURL("http://localhost:8080/geoserver/wms", params, this,
>> setHTML, setHTML);
>> => my setHTML-function now looks like that:
>> function setHTML(response){
>> var g = new OpenLayers.Format.XML();
>> var features = g.read(response.responseText);
>> var url = g.getAttributeNS(features.documentElement,
>> 'http://www.w3.org/2001/XMLSchema-instance', 'schemaLocation');
>> document.getElementById('nodelist').innerHTML=response.responseText;
>> document.getElementById('urlOutput').innerHTML=url;}
>> In this case it puts out the schemalocation in the urlOutput. But that´s
>> not
>> what I want to achieve. So the question is, how can i get other elements
>> out
>> of the XML like the ID for example.
>> For that I have to competely understand what all those methods do which
>> is
>> not the case yet ;-). For example the read-method: does it read the
>> content
>> of an XML-File node by node? Or the getAttributeNS-method: What does
>> features.documentElement (= the node) mean and why am I not able to refer
>> to
>> another name than 'schemalocation' (when I try url, which is an attribute
>> in
>> my layer it returns no result).
>> thanks for your help
>> Max Stephan
>> Ivan Grcic-2 wrote:
>>> Hi, did you check out http://openlayers.org/dev/examples/GMLParser.html
>>> Function load takes ur xml data (which can be getFeatureInfo), and
>>> gives it to parseData function, which parses all the features and
>>> their attributes...its all you need ;)
>>> And i suggest to make it in JSON format, its much lighter
>>>         function load() {
>>>             OpenLayers.loadURL("gml/owls.xml", "", null, parseData);
>>>           html = ""
>>>                 html += "<ul>";
>>>                 html +=
>>>                 html += "</ul>"
>>> Cheers
>>> On Tue, Feb 3, 2009 at 9:09 PM, Max Stephan <x.zam at gmx.net> wrote:
>>>> Ok, that sounds like an idea.
>>>> I´ve been reading a bit more about JavaScript-development in general.
>>>> So
>>>> I
>>>> developed the following change in the setHTML-function that allows me
>>>> to
>>>> show a picture when the function is executed.
>>>> var img = document.createElement("img");
>>>> img.setAttribute("src", "qu18_2.jpg");
>>>> document.getElementById('pic-container').replaceChild(img,document.getElementById('pic-container').lastChild);}
>>>> This works fine for a predefined pic. But how can I get the specific
>>>> attribute that contains the URL out of the getFeatureRequest-response.
>>>> So
>>>> what I´m searching for is something like "response.getContent[5]"
>>>> (fictional
>>>> code ;-)).
>>>> So, as you see, by now it´s a bit abstract to me what I exactly get
>>>> back
>>>> from this getFeatureRequest and how I can get further informations out
>>>> of
>>>> it...
>>>> Thank you for your help Ivan and Till and thanks to everyone else in
>>>> advance
>>>> Max Stephan
>>>> Till Adams wrote:
>>>>> Max,
>>>>> in general you need to define your output format which comes back from
>>>>> Geoserver as text or Xml or whatever - then you may parse the
>>>>> backcoming
>>>>> stuff and put the URL in an html image tag - basically you can see
>>>>> what
>>>>> to
>>>>> do regarding the OL featureinfo example::
>>>>> you must do alter it at the place when you receive the result from
>>>>> your
>>>>> WMS
>>>>> back and before you put it this in the result-div in your client -
>>>>> you'll
>>>>> have to parse it and rewrite it to html, alternatively you may define
>>>>> a
>>>>> template for your WMS which gives the results back in Html, so you can
>>>>> do
>>>>> sth like:
>>>>> <html>
>>>>>  [URL]
>>>>> Where [URL] will be filled by your WMS server - this is mainly the
>>>>> proceeding I know from UMN mapserver.
>>>>> Just some ideas - regards, Till
>>>>> "Max Stephan" <x.zam at gmx.net> schrieb:
>>>>>> Hey everybody!
>>>>>> I got a shapefile here which I added to my geoserver. I have
>>>>>> integrated
>>>>>> it
>>>>>> as a layer in an openlayers map container. In the attributes of the
>>>>>> layer/shapefile is a field which contains an URL to a pic of each
>>>>>> feature
>>>>>> (in this case the features are points). Now I want this picture to be
>>>>>> displayed in a popup (like it can be done in a marker layer). But I
>>>>>> want
>>>>> to
>>>>>> have the URL automatically read from the attributes of the feature
>>>>>> I´m
>>>>>> clicking on. It would be great to see some of the other attributes
>>>>>> read
>>>>> from
>>>>>> the feature as well. The problem is I don´t know that much about the
>>>>>> OpenLayers-API. I only know how to write a GetFeatureRequest but this
>>>>> would
>>>>>> show me only the attribute table. If it´s too difficult to show a
>>>>>> picture
>>>>>> which´s URL is in the attributes it would be even enough if the URL
>>>>>> in
>>>>>> the
>>>>>> attribute table (the one I get from the GetFeatureRequest) would be
>>>>>> clickable.
>>>>>> Greets and thanks for your help in advance Max Stephan
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>> Users mailing list
>>>> View this message in context:
>>>> http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2265382.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> Users mailing list
>>> Ivan Grcic
>>> Users mailing list
>> http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2268463.html
>> Users mailing list
> Users mailing list
View this message in context: http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2270577.html
