[OpenLayers-Users] How can I show a picture a popup (URL for
the pic should be read automatically from the attributes)
Max Stephan
x.zam at gmx.net
Thu Feb 5 05:11:44 EST 2009
Hey,
I was successfull getting it to work via GML. It now looks like this:
function setHTML(response){
var gmlparser = new OpenLayers.Format.GML();
var features = gmlparser.read(response.responseText);
var url;
var postart;
var postamt;
for(var feat in features) {
url = features[feat].attributes.url;
postart = features[feat].attributes.postart;
postamt = features[feat].attributes.postamt;
In the lines that follow I´m defining the output but that´s just basic
stuff. OK, now that I achieved this, there´s another question:
I´m going to query multiple layers that have different attributes. That
means I have to read from the GML which layer contains the current feature
to know which further reading-operations have to be done. One easy method
would be to add an attribute "type" to each layer which is read via
"features[feat].attributes.type" and to check this attribute with "if...
else". But it´ll be nicer if I could read the layer-Name directly. I found
the layerName-function in the API-Documentation of OpenLayers but the var
which should have contained the layerName always staid "undefined" (I tried
"features[feat].layerName" and "response.layerName").
Thx in advance and greets
Max Stephan
Ivan Grcic-2 wrote:
> Hi,
> im sorry i also dont know so much about Format.XML methods, i mostly
> use Format.GML or JSON
> but this should help:
> http://openlayers.org/dev/examples/xml.html
> http://dev.openlayers.org/docs/files/OpenLayers/Format/XML-js.html
> Cheers,
View this message in context: http://n2.nabble.com/How-can-I-show-a-picture-a-popup-%28URL-for-the-pic-should-be-read-automatically-from-the-attributes%29-tp2262546p2274122.html
