[OpenLayers-Users] buggy loadingPanel (vs Navigation/MouseDefaults) please help!
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Feb 5 03:15:54 EST 2009
Can you share an example HTML demonstrating the problem (and a clear
description of the problem). TIA.
Best regards,
Bart
z_o_d_ wrote:
> I am having the same problem as BrainDrain.
> It may be of interest that I only get this problem when configured to view
> yahoo base layers (although the yahoo layer itself does not have to be on
> the map).
> That is to say, I only get the problem when projecting to "EPSG:900913".
> Under the default projection, the loading pannel works fine.
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
